I am trying to accomplish the following task: I have a dropdown menu, and when I make changes to it, I want a popup to appear asking for a hardcoded password. Only if I enter the correct password, the msg.payload should be forwarded. If the password is incorrect, nothing should happen.
I have made an attempt at implementing this functionality, but it has not been successful so far. Currently, I have simulated it by using a submit button and a text field where I enter a password.
Here is the (non-working) part of the flow I have implemented so far:
"id": "546b8641ca8d48e6",
"type": "ui_dropdown",
"z": "36c6ded58f79fc83",
"label": "Dropdown",
"tooltip": "",
"place": "Select option",
"group": "cb79cf8d.1f211",
"order": 1,
"width": 0,
"height": 0,
"passthru": true,
"multiple": false,
"options": [
"label": "Option 1",
"value": "option1",
"type": "str"
"label": "Option 2",
"value": "option2",
"type": "str"
"label": "Option 3",
"value": "option3",
"type": "str"
"payload": "",
"topic": "",
"topicType": "str",
"className": "",
"x": 150,
"y": 660,
"7444fd3e81fec442"
"id": "7444fd3e81fec442",
"type": "ui_template",
"order": 2,
"width": 0,
"height": 0,
"format": "<div ng-init=\"showPopup = false\">\n <text-angular ng-show=\"showPopup\" ng-bind-html=\"popupContent\"></text-angular>\n</div>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 360,
"y": 660,
"b3d51745b4ef3d38"
"id": "b3d51745b4ef3d38",
"type": "function",
"name": "Check Password",
"func": "var password = 1234; // Hier das korrekte Passwort eintragen\n\nif (msg.payload == password) {\n msg.showPopup = false; // Popup-Fenster ausblenden, wenn das Passwort korrekt ist\n return msg; // Weiterleiten, wenn das Passwort korrekt ist\n} else {\n msg.showPopup = true; // Popup-Fenster anzeigen, wenn das Passwort falsch ist\n msg.popupContent = '<h2>Ungültiges Passwort</h2>'; // Fehlermeldung für das Popup-Fenster\n return msg; // Keine Weiterleitung\n}\n",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 570,
"y": 640,
"1d57627dafdbfc2e"
"id": "1d57627dafdbfc2e",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 750,
"y": 700,
"id": "cb79cf8d.1f211",
"type": "ui_group",
"name": "Dropdown",
"tab": "dd43e6da.7e8eb8",
"order": 1,
"disp": true,
"width": "6",
"collapse": false
"id": "dd43e6da.7e8eb8",
"type": "ui_tab",
"name": "Home",
"icon": "dashboard",
"order": 1,
"disabled": false,
"hidden": false
Maybe someone has an idea, hot solve this.
best regards
