in the dropdown node, the search string highlights the options with white on white, in dark theme, cant find which attribute controls this. any help plesae
.v-combobox__mask {
background: rgb(var(--v-theme-primary));
@hotnipi/@joepavitt is this something we should have baked into the dashboard CSS?
Using the --v-theme-primary here should be quite safe, but maybe to consider to reduce a bit opacity to the color to keep text a bit more stand out.
Yes please - was an issue opened?
