Hello
Is there any way to "jazz up" the dropdown node ... maybe using template to make it bigger, add colour?
thanks
You could apply CSS styling by adding styles a ui_template node set to "head"
I'm a bit lost with html. Could you elaborate a bit please.
thanks
If you want to titivate, you're gonna have to spend some time learning I'm afraid.
I'd start here...
https://www.w3schools.com/html/html_css.asp
Once you have the basics, you can start searching the net for "fancy drop-down CSS" etc then apply that to your own.
Its not terribly difficult to grasp and is a whole lotta fun (if you like that kinda thing)
I thought this stuff was specific to Node Red but you are saying it is generic. In that case I'm happy to research. Thanks
If you consider the dashboard is essentially a web page & all (most) web pages are HTML + CSS then you can make a leap of faith. I.e. it's all web technology so learn the web technology and you can titivate the dashboard
great...
thanks again
Hello
Now I'm stuck again. I have found some nice styles and pasted them into a template in dashboard. Looks good but I don't know how to generate a payload when an item is selected from the dropdown.
Depends what you did. Are you using the dashboard node drop-down or your own in a ui_template?
Export the relevant parts of your flow for us to see to be able to help you.
Remember to paste your export between three backticks...
like this
...to ensure your flow doesn't get mangled.
I just copy pasted an example into a template
[{"id":"60fb6658.20da28","type":"debug","z":"646e8fbc.b0c6a","name":"drop down","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":660,"y":540,"wires":[]},{"id":"f23553c6.ae238","type":"ui_template","z":"646e8fbc.b0c6a","group":"8bf0825d.36a2c","name":"dropdown","order":11,"width":0,"height":0,"format":"<!DOCTYPE html> \n<html> \n\t<head> \n\t\t<style> \n\t\t\th1 { \n\t\t\t\tcolor:green; \n\t\t\t} \n\t\t\tselect { \n\t\t\t\t-webkit-appearance: none; \n\t\t\t\t-moz-appearance: none; \n\t\t\t\t-ms-appearance: none; \n\t\t\t\tappearance: none; \n\t\t\t\toutline: 0; \n\t\t\t\tbackground: green; \n\t\t\t\tbackground-image: none; \n\t\t\t\tborder:1px solid black; \n\t\t\t} \n\t\t\t.select { \n\t\t\t\tposition: relative; \n\t\t\t\tdisplay: block; \n\t\t\t\twidth: 20em; \n\t\t\t\theight: 3em; \n\t\t\t\tline-height: 3; \n\t\t\t\tbackground: #2C3E50; \n\t\t\t\toverflow: hidden; \n\t\t\t\tborder-radius: .25em; \n\t\t\t} \n\t\t\tselect { \n\t\t\t\twidth: 100%; \n\t\t\t\theight: 100%; \n\t\t\t\tmargin: 0; \n\t\t\t\tpadding: 0 0 0 .5em; \n\t\t\t\tcolor: #fff; \n\t\t\t\tcursor: pointer; \n\t\t\t} \n\t\t\tselect::-ms-expand { \n\t\t\t\tdisplay: none; \n\t\t\t} \n\t\t\t.select::after { \n\t\t\t\tcontent: '\\25BC'; \n\t\t\t\tposition: absolute; \n\t\t\t\ttop: 0; \n\t\t\t\tright: 0; \n\t\t\t\tbottom: 0; \n\t\t\t\tpadding: 0 1em; \n\t\t\t\tbackground: #34495E; \n\t\t\t\tpointer-events: none; \n\t\t\t} \n\t\t\t.select:hover::after { \n\t\t\t\tcolor: #F39C12; \n\t\t\t} \n\t\t\t\n\t\t\t<!-- For different browsers -->\n\t\t\t.select::after { \n\t\t\t\t-webkit-transition: .25s all ease; \n\t\t\t\t-o-transition: .25s all ease; \n\t\t\t\ttransition: .25s all ease; \n\t\t\t} \n\t\t</style> \n\t</head> \n\t<body> \n\t\t<center> \n\t\n\t\t<div class=\"select\"> \n\t\t\t<select name=\"slct\" id=\"slct\"> \n\t\t\t <option value=\"volvo\">Volvo</option>\n\t\t\t\t<option>Computer Science Subjects</option> \n\t\t\t\t<option value=\"1\">Operating System</option> \n\t\t\t\t<option value=\"2\">Computer Networks</option> \n\t\t\t\t<option value=\"3\">Data Structure</option> \n\t\t\t\t<option value=\"4\">Algorithm</option> \n\t\t\t\t<option value=\"5\">C programming</option> \n\t\t\t\t<option value=\"6\">JAVA</option> \n\t\t\t</select> \n\t\t</div> \n\t\t</center> \n\t</body> \n</html>\t\t\t\t\t\t\t \n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":480,"y":540,"wires":[["60fb6658.20da28"]]},{"id":"8bf0825d.36a2c","type":"ui_group","z":0,"name":"buttons","tab":"b5ca2d9b.d2557","order":1,"disp":false,"width":6,"collapse":false},{"id":"b5ca2d9b.d2557","type":"ui_tab","z":0,"name":"Home","icon":"home","order":1}]
ok, first thing first,
the dashboard is already a HTML document (thats why it shows up in your browser) so you dont need <html>, <head> or <body> in the template - the only reason (the code you pasted) works is the browser is quite forgiving.
Secondly, just copying an pasting isn't going to teach you much - but hey ho.
Here you go, this works - but you'll have difficulty understanding it or implementing more than one if you dont get to grips with JS / HTML / CSS
[{"id":"697e8390.573ddc","type":"debug","z":"c70ba4a4.e7fb58","name":"drop down","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":830,"y":540,"wires":[]},{"id":"72cd3d4e.7feae4","type":"ui_template","z":"c70ba4a4.e7fb58","group":"deeae69a.e7f598","name":"dropdown","order":1,"width":0,"height":0,"format":"<script>\n this.scope.onSelectChange = function(el){\n var v = $(el).val();\n this.send({payload:v})\n }\n</script>\n\n<div class=\"select\"> \n\t<select name=\"slct\" id=\"slct\" \n\t onchange=\"angular.element(this).scope().onSelectChange(this)\"> \n\t\t<option value=\"1\">Operating System</option> \n\t\t<option value=\"2\">Computer Networks</option> \n\t\t<option value=\"3\">Data Structure</option> \n\t\t<option value=\"4\">Algorithm</option> \n\t\t<option value=\"5\">C programming</option> \n\t\t<option value=\"6\">JAVA</option> \n\t</select> \n</div> \n\n\t\t\t\t \n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":680,"y":540,"wires":[["697e8390.573ddc"]]},{"id":"27a64d91.ea40f2","type":"ui_template","z":"c70ba4a4.e7fb58","group":"deeae69a.e7f598","name":"styles","order":2,"width":0,"height":0,"format":"<style> \n\th1 { \n\t\tcolor:green; \n\t} \n\tselect { \n\t\t-webkit-appearance: none; \n\t\t-moz-appearance: none; \n\t\t-ms-appearance: none; \n\t\tappearance: none; \n\t\toutline: 0; \n\t\tbackground: green; \n\t\tbackground-image: none; \n\t\tborder:1px solid black; \n\t} \n\t.select { \n\t\tposition: relative; \n\t\tdisplay: block; \n\t\twidth: 20em; \n\t\theight: 3em; \n\t\tline-height: 3; \n\t\tbackground: #2C3E50; \n\t\toverflow: hidden; \n\t\tborder-radius: .25em; \n\t} \n\tselect { \n\t\twidth: 100%; \n\t\theight: 100%; \n\t\tmargin: 0; \n\t\tpadding: 0 0 0 .5em; \n\t\tcolor: #fff; \n\t\tcursor: pointer; \n\t} \n\tselect::-ms-expand { \n\t\tdisplay: none; \n\t} \n\t.select::after { \n\t\tcontent: '\\25BC'; \n\t\tposition: absolute; \n\t\ttop: 0; \n\t\tright: 0; \n\t\tbottom: 0; \n\t\tpadding: 0 1em; \n\t\tbackground: #34495E; \n\t\tpointer-events: none; \n\t} \n\t.select:hover::after { \n\t\tcolor: #F39C12; \n\t} \n\t\n\t<!-- For different browsers -->\n\t.select::after { \n\t\t-webkit-transition: .25s all ease; \n\t\t-o-transition: .25s all ease; \n\t\ttransition: .25s all ease; \n\t} \n</style> \n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"global","x":670,"y":500,"wires":[[]]},{"id":"deeae69a.e7f598","type":"ui_group","z":"","name":"buttons","tab":"13129af8.35fd85","order":1,"disp":false,"width":"9","collapse":false},{"id":"13129af8.35fd85","type":"ui_tab","z":0,"name":"Home","icon":"home","order":1}]
thank you so much.
When I said I "just" did a cut and paste, I meant that I had spent time discovering CSS and some html tidbits, before experimenting with some code. I do some coding in VB NET and Arduino but this is a whole new field to me. I can get the html bit and CSS but the JS??
Maybe I'm using the wrong technique but the dropdown code includes "onSelectChange"
I would love to have a fixed header that says "choose an option" which on click shows a list of options to click. Then after clicking one restore to "choose an option"
It takes time & lots of play
Its a quite a different mindset to .NET / client side programming but you at least (I imagine through VB.NET and C from Aurduino) have an understanding of objects, properties, setting values etc.
The bits to learn for HTML / JS are not so different except always remember things are stateless (each page refresh - things start again)
good luck
I'm back!
I've been experimenting and modifying some examples which do what I want. Unfortunately this one works well (except for outputting a payload) in my windows web server but has strange behaviour within dashboard. I am way out of my depth. Anyone help please.
[{"id":"50036c9b.c44cec","type":"ui_template","z":"5081acab.0242b4","group":"b61097ba.80be5","name":"","order":2,"width":0,"height":0,"format":"\n\n\n<script>\nvar _hmt = _hmt || [];\n(function() {\nvar hm = document.createElement(\"script\");\nhm.src = \"//hm.baidu.com/hm.js?73c27e26f610eb3c9f3feb0c75b03925\";\nvar s = document.getElementsByTagName(\"script\")[0];\ns.parentNode.insertBefore(hm, s);\n})();\n\nfunction myTest() {\nalert(\"you pressed test 3 via a function and would like to pass on as a payload\");\n}\n</script>\n\n\n<div class=\"dropdown\">\n<button onclick=\"myFunction()\" class=\"dropbtn\">Dropdown</button>\n <div id=\"myDropdown\" class=\"dropdown-content\">\n<a href=\"javascript:alert('you pressed test1');\">Test1</a>\n<a href=\"javascript:alert('you pressed test2');\">Test2</a>\n<a href=\"#\" onclick=\"myTest()\">Test3</a>\n </div>\n</div>\n<p id=\"demo\"></p>\n\n\n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":720,"y":420,"wires":[["6f0dc163.19bb48"]]},{"id":"1287f23e.e9c836","type":"ui_template","z":"5081acab.0242b4","group":"2b599cf9.f7374c","name":"mystyle","order":2,"width":0,"height":0,"format":"<style>\n.dropbtn {\n background-color: #4CAF50;\n color: cyan;\n padding: 16px;\n font-size: 16px;\n border: none;\n cursor: pointer;\n\n}\n\n.dropbtn:hover, .dropbtn:focus {\n background-color: #3e8e41;\n}\n\n.dropdown {\n position: relative;\n display: inline-block;\n}\n\n.dropdown-content {\n display: none;\n position: absolute;\n background-color: #f9f9f9;\n min-width: 160px;\n overflow: auto;\n box-shadow: 0px 8px 16px 0px rgba(0,0,0,0.2);\n}\n\n.dropdown-content a {\n color: black;\n padding: 12px 16px;\n text-decoration: none;\n display: block;\n}\n\n.dropdown a:hover {background-color: #f1f1f1}\n\n.show {display:block;}\n</style>\n<script>\n/* When the user clicks on the button, \ntoggle between hiding and showing the dropdown content */\nfunction myFunction() {\n document.getElementById(\"myDropdown\").classList.toggle(\"show\");\n}\n\n// Close the dropdown if the user clicks outside of it\nwindow.onclick = function(event) {\n if (!event.target.matches('.dropbtn')) {\n\n// var x = document.getElementsByClassName(\"dropdown-content\");\n// document.getElementById(\"demo\").innerHTML = \"You selected: \" + x;\n // var x = document.getElementById(\"myDropdown\").value;\n// document.getElementById(\"demo\").innerHTML = \"You selected: \" + x;\n\n\n var dropdowns = document.getElementsByClassName(\"dropdown-content\");\n var i;\n for (i = 0; i < dropdowns.length; i++) {\n var openDropdown = dropdowns[i];\n if (openDropdown.classList.contains('show')) {\n openDropdown.classList.remove('show');\n }\n }\n }\n}\n\n\n\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":700,"y":360,"wires":[[]]},{"id":"6f0dc163.19bb48","type":"debug","z":"5081acab.0242b4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":900,"y":420,"wires":[]},{"id":"b61097ba.80be5","type":"ui_group","name":"Group 1","tab":"5d4402ab.d95724","order":1,"disp":true,"width":6},{"id":"2b599cf9.f7374c","type":"ui_group","z":"","name":"buttons","tab":"d029df62.a8cad8","order":1,"disp":false,"width":"9","collapse":false},{"id":"5d4402ab.d95724","type":"ui_tab","name":"Tab 3","icon":"dashboard","order":3},{"id":"d029df62.a8cad8","type":"ui_tab","z":0,"name":"Home","icon":"home","order":1}]
