Dynamic min max artless gauge dont work
I need to set min and max dynamically.
In my flow this works Ok with normal gauge but dont work with artless linear gauge.
How to solve?
flows (11).json (5.4 KB)
There is ui_level node in your not the artless gauge.
Anyway, best is to read the help of the node. It says clearly how runtime configuration works. And yes it is a bit different.
The segments's values also customizable within the configuration or by using msg.control = {seg1:30, seg2:60}.
so close every time, but so far away that it would work :wink:
