Dynamic routing to widgets
OMG : this not only works, but so easy - and visually great !!!!!
Thank you for this !! It is really something else !! Saves effing tons of work and cluttered dashes
We need a screenshot Alf!!!
Dude - I just deleted and started anew - there really isn't much to see here - I will post when I deploy irl (sometime next week hopefully).
sc2
NB: the latest version of FD fixes the issue with missing labels: if you remove labels now you should have no legend and a bit more space for the plot itself. Whether you prefer that or not is up to you....
Ughh, I now realize the on-hover tooltip shows "series 1", I need to fix that :roll_eyes:
Here are screenshots from the actual POC with 5 sensors - there will be 5 more asap.
So easy ....
Dude - no biggie - I am just over the moon that I don't have to individually program and layout for all individual sensors..
I will say one thing I just realised - it seems the timelines only get/accept data as long as the window to the dash is open - the nodes themselves do not retain data for a small period of time ?
Is that on your development-list of features ?
Yes, I'm not sure yet what it should exactly do.
From what I see your data is all in-memory, so you need to buffer it explicitly. Currently you are sending one data point at a time to the widget. You need to build up the array of all data points to display and send it the full array.
So write a "data buffer" function node that, for each topic (i.e. plot) collects the last N data points in an array saved in the node context. Something like: (untested):
let data = node.get(msg.topic) || [] // get saved data for this topic
data.push(msg.data) // append new data point
while (data.length > 100) data.shift() // remove excess data points
node.set(msg.topic, data) // save the new dataset
msg.data = data // output the full dataset
return msg
What's currently missing is a way to efficiently transmit this to the dashboard, i.e., not send all the data every time. Although, you won't really notice any difference...
Works like a charm with one small mod - context.get and context.set - not node.get/set this time.
Mvh
Alf Møllerud (+47 93267132)
