hello .. i worked a little bit on the restructuring of the data.
it needs a lot of processing and i dont know how easy it is to do it straight from Mongodb queries.
if you are interested to see the javascript ...
Test Flow:
flows.json (65.0 KB)
Some problem i noticed was that not all objects had data so those had to filtered
Added vue v-if v-else conditional rendering of a warning msg
when no data has been received from Node-red
<body>
<div id="app">
<b-container id="app_container" fluid class="ml-5">
<h1 class="mt-5">Vue-apexcharts in Uibuilder</h1>
<b-row v-if="chartData.length > 0" >
<b-card col class="mt-3 m-3" style="width: 40%;" v-for="(chart,index) in chartData" :key="index"
><apexchart width="95%" :options="chart.chartOptions" :series="chart.chartSeries"></apexchart
></b-card>
</b-row>
<b-row v-else class="ml-2 mt-5"><b-alert show variant="warning" class="w-75">No data received from NR yet</b-alert></b-row>
</b-container>
</body>
index.js
/** Reference the apexchart component (removes need for a build step) */
Vue.component("apexchart", VueApexCharts);
var app1 = new Vue({
el: "#app",
data: {
// Data for apex charts
chartData: [],
}, // --- End of data --- //
computed: {}, // --- End of computed --- //
methods: {}, // --- End of methods --- //
// Available hooks: init,mounted,updated,destroyed
mounted: function() {
uibuilder.start();
var vueApp = this;
// Process new messages from Node-RED
uibuilder.onChange("msg", function(msg) {
if (msg) {
console.table(msg.payload[0].chartSeries[0].data);
console.log(msg.payload);
vueApp.chartData = msg.payload;
}, // --- End of mounted hook --- //
}); // --- End of app1 --- //
// EOF
