So what in wanting to do is add rules into a change node by using dashboard forms, is there anyways to do this?
Some way to send a payload that will add a rule into the change node?
You can send an update flow json to node-red using the admin api Admin API Methods : Node-RED
This will not be a trivial task. you will need to get the flow json and update the change node properties then upload the new flow json.
is this the same question?
awesome! i will give that a try!!
and yes it was the same question, I thought i would post it in a different category
