eMail node and NodeJs 20
I updated from NodeJS 18 to NodeJs 20, and when I try to update email node from 2.0.0 to 2.0.1 I get the following error:
npm WARN config production Use `--omit=dev` instead.
npm ERROR! code EBADENGINE
npm ERROR! engine Unsupported engine
npm ERROR! engine Not compatible with your version of node/npm: @azure/msal-node@1.17.2
npm ERROR! notsup Not compatible with your version of node/npm: @azure/msal-node@1.17.2
npm ERROR! notsup Required: {"node":"10 || 12 || 14 || 16 || 18"}
npm ERROR! notsup Current: {"npm":"10.1.0","node":"v20.6.1"}
The issue/error is clearly shown, contact the node maintainers on github and ask if/when they may upgrade nodejs support
In the meantime downgrade your nodejs to 18.
The error was clear to me as well. In general, dceejay handles the node, when I found problems I posted here, I knew that dceejay is very prompt.
I'm actually waiting for an update :slight_smile:
Issues should be raised in the issue section on github, that way it is logged and the maintainer has a clear record.
Done : node-red-node-email and NodeJs 2 Ā· Issue #1029 Ā· node-red/node-red-nodes Ā· GitHub
answer on issue.
