Enable light when door open (between times and set duration)
OK try this flow
[{"id":"41fafddd.381444","type":"comment","z":"56d3c1c6.0d901","name":"Door Open","info":"Send to the Ligth Node to switch on","x":920,"y":600,"wires":[]},{"id":"4f75983f.a459c8","type":"comment","z":"56d3c1c6.0d901","name":"Door Closed - Switch off light - Change Colour","info":"Turn the light off","x":1030,"y":760,"wires":[]},{"id":"e6cb300a.a589f","type":"inject","z":"56d3c1c6.0d901","name":"Door Open","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"On","payloadType":"str","x":160,"y":500,"wires":[["4c5be29d.2f8a0c"]]},{"id":"279cd515.c5d3ba","type":"change","z":"56d3c1c6.0d901","name":"Set COntext for Door to Open","rules":[{"t":"set","p":"DoorState","pt":"flow","to":"Open","tot":"str"},{"t":"set","p":"LightColour","pt":"flow","to":"LightColour","tot":"msg"},{"t":"set","p":"LightColour","pt":"msg","to":"Red","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":640,"wires":[["9de4da00.350d58"]]},{"id":"4c5be29d.2f8a0c","type":"mytimeout","z":"56d3c1c6.0d901","name":"Check for Door Open too long","outtopic":"","outsafe":"Open","outwarning":"","outunsafe":"OpenTooLong","warning":"-","timer":"300","debug":false,"ndebug":false,"ignoreCase":true,"repeat":false,"again":false,"x":390,"y":500,"wires":[["632e19a9.3651d8"],[]]},{"id":"a486dfec.e2fde","type":"inject","z":"56d3c1c6.0d901","name":"Door Closed","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Cancel","payloadType":"str","x":150,"y":560,"wires":[["4c5be29d.2f8a0c","632e19a9.3651d8"]]},{"id":"632e19a9.3651d8","type":"switch","z":"56d3c1c6.0d901","name":"Monitor Door State","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Open","vt":"str"},{"t":"eq","v":"Cancel","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":680,"wires":[["279cd515.c5d3ba"],["74665c94.85bf04"]]},{"id":"74665c94.85bf04","type":"change","z":"56d3c1c6.0d901","name":"Set COntext for Door to Closed","rules":[{"t":"set","p":"DoorState","pt":"flow","to":"Closed","tot":"str"},{"t":"set","p":"LightColour","pt":"msg","to":"LightColour","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":720,"wires":[["cb7daab.ea53558"]]},{"id":"cb7daab.ea53558","type":"debug","z":"56d3c1c6.0d901","name":"Door CLosed Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":960,"y":720,"wires":[]},{"id":"9de4da00.350d58","type":"debug","z":"56d3c1c6.0d901","name":"Door Open","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":640,"wires":[]}]
I have used a Contrib node - My Timeout by Neil Cherry - you will need to download and install this
I have assumed the following
  1. Your incoming message from the Light Websocket will have information about the Colour and State of the switch - you can see the values i have used - you can adjust those values accordingly
  2. I have used debug nodes as output - you will need to include the Websocket nodes to communicate your light state and colour - again this will need to be adjusted as appropriate.
Craig
Looks great, thank you.
One last question. the output of the change node is send to the debug node.
I have added the light now, but how do I configure the light to receive the correct output of the change node ?
Now the light node is configured with a specific color, but there is no intelligence added to adjust the color.
        "id": "6b3c2aac85c94b44",
        "type": "api-call-service",
        "z": "f6f2187d.f17ca8",
        "name": "Onder",
        "server": "76e2ef2e0bfaa238",
        "version": 3,
        "debugenabled": false,
        "service_domain": "light",
        "service": "turn_on",
        "entityId": "light.eettafel_onder",
        "data": "",
        "dataType": "jsonata",
        "mergecontext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 970,
        "y": 1040,
        "id": "d69eafe69d998078",
        "type": "comment",
        "name": "Door Open",
        "info": "Send to the Ligth Node to switch on",
        "x": 980,
        "y": 960,
        "id": "4f043794bc8398a2",
        "type": "comment",
        "name": "Door Closed - Switch off light - Change Colour",
        "info": "Turn the light off",
        "x": 1090,
        "y": 1120,
        "id": "789515953c6cce8b",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "On",
        "payloadType": "str",
        "x": 180,
        "y": 920,
                "e98a45a6118c805a"
        "id": "b99797c32e6ffb72",
        "type": "change",
        "name": "Set COntext for Door to Open",
        "rules": [
                "t": "set",
                "p": "DoorState",
                "pt": "flow",
                "to": "Open",
                "tot": "str"
                "t": "set",
                "p": "LightColour",
                "pt": "flow",
                "to": "LightColour",
                "tot": "msg"
                "t": "set",
                "p": "LightColour",
                "pt": "msg",
                "to": "Red",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 690,
        "y": 1040,
                "d8a08591a0fde469",
                "6b3c2aac85c94b44"
        "id": "3aa0894571362c3a",
        "type": "inject",
        "name": "Door Closed",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "Cancel",
        "x": 170,
        "y": 1080,
                "e98a45a6118c805a",
                "647e81110266134c"
        "id": "647e81110266134c",
        "type": "switch",
        "name": "Monitor Door State",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "Open",
                "vt": "str"
                "t": "eq",
                "v": "Cancel",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 410,
        "y": 1080,
                "b99797c32e6ffb72"
                "3044635c66218313"
        "id": "3044635c66218313",
        "type": "change",
        "name": "Set COntext for Door to Closed",
        "rules": [
                "t": "set",
                "p": "DoorState",
                "pt": "flow",
                "to": "Closed",
                "tot": "str"
                "t": "set",
                "p": "LightColour",
                "pt": "msg",
                "tot": "flow"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 690,
        "y": 1160,
                "b0419bcd10ef1bb1",
                "e58d279209886bf2"
        "id": "b0419bcd10ef1bb1",
        "type": "debug",
        "name": "Door CLosed Debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1020,
        "y": 1160,
        "id": "d8a08591a0fde469",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 990,
        "y": 1000,
        "id": "e98a45a6118c805a",
        "type": "mytimeout",
        "name": "Check for Door Open too long",
        "outtopic": "",
        "outsafe": "Open",
        "outwarning": "",
        "outunsafe": "OpenTooLong",
        "warning": "-",
        "timer": "3",
        "debug": false,
        "ndebug": false,
        "ignoreCase": true,
        "repeat": false,
        "again": false,
        "x": 410,
        "y": 1000,
                "647e81110266134c"
        "id": "6722d850486aab21",
        "type": "server-state-changed",
        "name": "Tussendeur",
        "version": 3,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "binary_sensor.deurcontact_tussendeur_contact",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "state_type": "str",
        "haltifstate": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "outputs": 1,
        "output_only_on_state_change": true,
        "for": 0,
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 130,
        "y": 1000,
                "e98a45a6118c805a"
        "id": "e58d279209886bf2",
        "name": "Onder",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 970,
        "y": 1200,
        "id": "76e2ef2e0bfaa238",
        "type": "server",
        "name": "Home Assistant",
        "version": 2,
        "addon": false,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": true,
        "cacheJson": true,
        "heartbeat": false,
        "heartbeatInterval": "30"
I can not import that flow - please format it correctly you need the
Flow Here
For this to work correctly
You need to identify and capture the incoming property that specifies what you current light colour is (thats what the flow context saving does) , then you need to set it to whatever colour you require to show the door is open
I can not tell you what these variables/entities/values are as they vary by type/brand of light that you are using
You will need to capture the incoming message from HA and put a debug on it so we can see what it contains
Craig
