Well you have a couple of instances here
Door opened - light turned on - presumably to last colour set ? or is it to a default colour ? If it is to a default colour then you do not need to do anything extra (presumably) as your Turn on Light node will set that then - if it is to a different colour then i would set another Flow Variable - that stored the value of the colour - not sure how you are setting this is is HVS, RGB or just by name ? But whatever it is then store that at the time you set it and put in the flow context
Door left open to long - colour changes - presumably to a new fixed colour ? Nothing special to do here - you already have the trigger node that times out so you just set the new value in that object that switches the light
If the door closes then you need to negate the trigger node so you will need a link into the trigger from the close switch - like this
[{"id":"91ee800c.97882","type":"inject","z":"56d3c1c6.0d901","name":"Door Open","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Open","payloadType":"str","x":210,"y":140,"wires":[["f2e11a79.f8f9c8"]]},{"id":"9523cd6b.1bd71","type":"inject","z":"56d3c1c6.0d901","name":"Door Closed","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Closed","payloadType":"str","x":220,"y":280,"wires":[["f2e11a79.f8f9c8"]]},{"id":"f2e11a79.f8f9c8","type":"switch","z":"56d3c1c6.0d901","name":"Monitor Door State","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Open","vt":"str"},{"t":"eq","v":"Closed","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":420,"y":220,"wires":[["c4cc5acf.ad66d8"],["8a95533a.011cd"]]},{"id":"c4cc5acf.ad66d8","type":"change","z":"56d3c1c6.0d901","name":"Set COntext for Door to Open","rules":[{"t":"set","p":"DoorState","pt":"flow","to":"Open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":200,"wires":[["e4efbbfa.3a0358"]]},{"id":"8a95533a.011cd","type":"change","z":"56d3c1c6.0d901","name":"Set Context to Door Closed","rules":[{"t":"set","p":"DoorState","pt":"flow","to":"Closed","tot":"str"},{"t":"set","p":"reset","pt":"msg","to":"Yes","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":260,"wires":[["ae9d0d4a.80ab8","e4efbbfa.3a0358"]]},{"id":"e4efbbfa.3a0358","type":"trigger","z":"56d3c1c6.0d901","name":"Pause on Door Open","op1":"Open","op2":"StillOpen","op1type":"str","op2type":"str","duration":"1","extend":true,"overrideDelay":false,"units":"s","reset":"Open","bytopic":"all","topic":"topic","outputs":2,"x":1020,"y":160,"wires":[["251d4d76.9e62a2"],["80347b0e.3b4868"]]},{"id":"41fafddd.381444","type":"comment","z":"56d3c1c6.0d901","name":"Door Open","info":"Send to the Ligth Node to switch on","x":1220,"y":100,"wires":[]},{"id":"251d4d76.9e62a2","type":"debug","z":"56d3c1c6.0d901","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1230,"y":140,"wires":[]},{"id":"ff601f50.cfafa","type":"comment","z":"56d3c1c6.0d901","name":"Door Left Open","info":"Change the color of the light as door open too long","x":1240,"y":260,"wires":[]},{"id":"80347b0e.3b4868","type":"debug","z":"56d3c1c6.0d901","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1230,"y":300,"wires":[]},{"id":"4f75983f.a459c8","type":"comment","z":"56d3c1c6.0d901","name":"Door Closed - Switch off light","info":"Turn the light off","x":1060,"y":360,"wires":[]},{"id":"ae9d0d4a.80ab8","type":"debug","z":"56d3c1c6.0d901","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1010,"y":400,"wires":[]}]
Craig
