Energy Dashboard + SQL
Hi
my goal is to have a energy-dashboard for multiple consumers and a SQL-database for saving data. Hardware is up and running.
Thanks to this forum, I already can read out all relevant data via modbus (node-red-contrib-modbus). I also have a basic dashboard (node-red-dashboard) and writing to SQL works (node-red-node-sqlite).
Now I have some (basic) questions regarding more detailed data-processing, where I have not found solutions yet. I will ask the questions step by step...
I read the electric power P1 and P2 from two different consumers and display them. In some cases I also want to display the sum (P1+P2) or even the difference (P1-P2) - how can I do that?
Here is a small extraction of my project
[{"id":"358902bd362de869","type":"group","z":"5c1cfa6176e89b23","name":"Test","style":{"label":true},"nodes":["84dd32dc7b3e9315","e2d73a893eba36cf","9c9667531623af10","bc59c19b8e7f3a79","9b8d97ddc575370a","6605234fe61afaf0","42cd4f2a9408be84","a24123c84780aed0","3eef6e0e5df04f6e"],"x":74,"y":99,"w":972,"h":262},{"id":"84dd32dc7b3e9315","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P1 (W)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"6","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":140,"wires":[["e2d73a893eba36cf"],[]]},{"id":"e2d73a893eba36cf","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Power","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":140,"wires":[["bc59c19b8e7f3a79"]]},{"id":"9c9667531623af10","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":920,"y":140,"wires":[]},{"id":"bc59c19b8e7f3a79","type":"function","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"convert (W to kW) & rounding","func":"msg.payload = Math.round((msg.payload/1000) * 10) / 10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":140,"wires":[["9c9667531623af10"]]},{"id":"9b8d97ddc575370a","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P2 (W)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"255","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":240,"wires":[["6605234fe61afaf0"],[]]},{"id":"6605234fe61afaf0","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Power","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":240,"wires":[["42cd4f2a9408be84"]]},{"id":"42cd4f2a9408be84","type":"function","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"convert (W to kW) & rounding","func":"msg.payload = Math.round((msg.payload/1000) * 10) / 10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":240,"wires":[["a24123c84780aed0"]]},{"id":"a24123c84780aed0","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":920,"y":240,"wires":[]},{"id":"3eef6e0e5df04f6e","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1+P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":930,"y":320,"wires":[]},{"id":"1fa6af670418434d","type":"modbus-client","name":"Trafo 7 Schneider","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"172.20.39.211","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"0","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true,"showWarnings":true,"showLogs":true},{"id":"a51173d2f89918d2","type":"ui_group","name":"Dashboard_Test","tab":"914279a7ba6a5984","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"914279a7ba6a5984","type":"ui_tab","name":"By_Dashboard","icon":"dashboard","disabled":false,"hidden":false}]
In case someone also has advice / proposal for optimization (e.g. making things easier), this is also very welcome... I'm still a beginner in Node-Red.
Thanks in advance.
To operate on properties from different messages you need to get them into the same message. There are 2 main ways of doing so.
  • Join node
  • Store values in context, retrieve from context when you need to use them
See this article in the cookbook for an example of how to join messages into one object.
Instead of duplicating function nodes, I would recommend you get to grips with the Link-Call nodes
thank you Steve-Mcl - great hint... this will be agreat help in a big dashboard and improves clarity
also thanks for the hint with "join"... I tried now for quite some time but did not get it working... probably because I'm not very familar with msg.payload / msg.parts... is join also to way to make P1-P2 instead of P1+P2?
I also didn't understand this hint??? sorry, I'm a newbie in node-red
[{"id":"358902bd362de869","type":"group","z":"5c1cfa6176e89b23","name":"Test","style":{"label":true},"nodes":["84dd32dc7b3e9315","e2d73a893eba36cf","9c9667531623af10","9b8d97ddc575370a","6605234fe61afaf0","a24123c84780aed0","3eef6e0e5df04f6e","6ce3dbb2a89cbc54","853f3cdb4f2eb2ce","79023a40718d81ea","96167288014520bc","392a13672de977ff","8d5be842405e35a6","e52092998ed2162b"],"x":74,"y":99,"w":1312,"h":342},{"id":"84dd32dc7b3e9315","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P1 (W)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"6","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":140,"wires":[["e2d73a893eba36cf"],[]]},{"id":"e2d73a893eba36cf","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Power","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":140,"wires":[["392a13672de977ff"]]},{"id":"9c9667531623af10","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":140,"wires":[]},{"id":"9b8d97ddc575370a","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P2 (W)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"255","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":240,"wires":[["6605234fe61afaf0"],[]]},{"id":"6605234fe61afaf0","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Power","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":240,"wires":[["8d5be842405e35a6"]]},{"id":"a24123c84780aed0","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":240,"wires":[]},{"id":"3eef6e0e5df04f6e","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1+P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1270,"y":320,"wires":[]},{"id":"6ce3dbb2a89cbc54","type":"join","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":990,"y":320,"wires":[["3eef6e0e5df04f6e","e52092998ed2162b"]]},{"id":"853f3cdb4f2eb2ce","type":"link in","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link in 1","links":[],"x":445,"y":380,"wires":[["96167288014520bc"]]},{"id":"79023a40718d81ea","type":"link out","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link out 1","mode":"return","links":[],"x":835,"y":380,"wires":[]},{"id":"96167288014520bc","type":"function","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"convert (W to kW) & rounding","func":"msg.payload = Math.round((msg.payload/1000) * 10) / 10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":380,"wires":[["79023a40718d81ea"]]},{"id":"392a13672de977ff","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":140,"wires":[["9c9667531623af10","6ce3dbb2a89cbc54"]]},{"id":"8d5be842405e35a6","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":240,"wires":[["a24123c84780aed0","6ce3dbb2a89cbc54"]]},{"id":"e52092998ed2162b","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 93","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1140,"y":400,"wires":[]},{"id":"1fa6af670418434d","type":"modbus-client","name":"Trafo 7 Schneider","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"172.20.39.211","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"0","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true,"showWarnings":true,"showLogs":true},{"id":"a51173d2f89918d2","type":"ui_group","name":"Dashboard_Test","tab":"914279a7ba6a5984","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"914279a7ba6a5984","type":"ui_tab","name":"By_Dashboard","icon":"dashboard","disabled":false,"hidden":false}]
ADMIN Edit: Put triple backticks be on their own line - for correct formatting of code blocks
You can learn a lot from the example flows for the Join node.
Go to the hamburger menu, Import. (or CTRL-i)
Select Examples, then Node-red, Sequence and Join
Study options 01 and 02, the most common usages for Join.
this is indeed also a good hint... didn't know about this before... thanks...
after some trials, I'm asking myself, if this is realy what I need... probably I formulated my request bad...
I want the sum of two values P1+P2 (e.g. 20kW + 30kW = 50kW; 60kW - 10kW =50kW)...
with join it looks to me, that I can combine two strings in one string?
I assume that P1 and P2 arrive in Node-red as two seperate messages.
Most nodes can only process one message at a time.
They retain no data from the previous message.
So you have to either ensure that the two values are in the same message (Join) or else store the first one in a context variable.
These are the two alternatives @Steve-Mcl gave you.
Usually the join option is better because context variables are potentially open to being changed by another flow or event. (variables whose scope is confined to a single function node are fairly safe from this).
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
thank you very much for your patience...
finally I understood it :slight_smile: and managed to make the sum... but does it also works for substraction? here I always end up with "undefined" in debug node 231
[{"id":"358902bd362de869","type":"group","z":"5c1cfa6176e89b23","name":"Test","style":{"label":true},"nodes":["84dd32dc7b3e9315","e2d73a893eba36cf","9c9667531623af10","9b8d97ddc575370a","6605234fe61afaf0","a24123c84780aed0","3eef6e0e5df04f6e","6ce3dbb2a89cbc54","853f3cdb4f2eb2ce","79023a40718d81ea","96167288014520bc","392a13672de977ff","8d5be842405e35a6","e52092998ed2162b","f02e3d60ec1f4f19","bf58219a946785a8","eb57d4e94eaf8dac"],"x":74,"y":99,"w":1312,"h":382},{"id":"84dd32dc7b3e9315","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P1 (W)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"6","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":140,"wires":[["e2d73a893eba36cf"],[]]},{"id":"e2d73a893eba36cf","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Power","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":140,"wires":[["392a13672de977ff"]]},{"id":"9c9667531623af10","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":140,"wires":[]},{"id":"9b8d97ddc575370a","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P2 (W)","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"255","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"5","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":240,"wires":[["6605234fe61afaf0"],[]]},{"id":"6605234fe61afaf0","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"Power","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":240,"wires":[["8d5be842405e35a6"]]},{"id":"a24123c84780aed0","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":240,"wires":[]},{"id":"3eef6e0e5df04f6e","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1+P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1270,"y":320,"wires":[]},{"id":"6ce3dbb2a89cbc54","type":"join","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":",","joinerType":"str","useparts":false,"accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":830,"y":320,"wires":[["f02e3d60ec1f4f19","bf58219a946785a8"]]},{"id":"853f3cdb4f2eb2ce","type":"link in","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link in 1","links":[],"x":125,"y":380,"wires":[["96167288014520bc"]]},{"id":"79023a40718d81ea","type":"link out","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link out 1","mode":"return","links":[],"x":515,"y":380,"wires":[]},{"id":"96167288014520bc","type":"function","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"convert (W to kW) & rounding","func":"msg.payload = Math.round((msg.payload/1000) * 10) / 10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":380,"wires":[["79023a40718d81ea"]]},{"id":"392a13672de977ff","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":140,"wires":[["9c9667531623af10","6ce3dbb2a89cbc54"]]},{"id":"8d5be842405e35a6","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":240,"wires":[["a24123c84780aed0","6ce3dbb2a89cbc54"]]},{"id":"e52092998ed2162b","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 93","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1240,"y":380,"wires":[]},{"id":"f02e3d60ec1f4f19","type":"change","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"sum","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":320,"wires":[["3eef6e0e5df04f6e","e52092998ed2162b"]]},{"id":"bf58219a946785a8","type":"change","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"substraction","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.two-payload.one","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":440,"wires":[["eb57d4e94eaf8dac"]]},{"id":"eb57d4e94eaf8dac","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 231","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1250,"y":440,"wires":[]},{"id":"1fa6af670418434d","type":"modbus-client","name":"Trafo 7 Schneider","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"172.20.39.211","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"0","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true,"showWarnings":true,"showLogs":true},{"id":"a51173d2f89918d2","type":"ui_group","name":"Dashboard_Test","tab":"914279a7ba6a5984","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"914279a7ba6a5984","type":"ui_tab","name":"By_Dashboard","icon":"dashboard","disabled":false,"hidden":false}]
Not quite. You need to use the Join node in key/value mode as described in the cookbook article linked earlier. Then you will be able to tell which item is which. Which doesn't matter when summing but does matter when taking the difference. Go back and look at that article again.
thank you for this clear hint... and you are absolutly right... after long trial & error, I managed to get it working for a simple example
[{"id":"93f16891d794e03b","type":"join","z":"5c1cfa6176e89b23","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":true,"accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":390,"y":1020,"wires":[["e9111659cebc98f5","f9f8aa7f58db37fc"]]},{"id":"70b47bac5cae85b0","type":"inject","z":"5c1cfa6176e89b23","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"P1","payload":"10","payloadType":"num","x":250,"y":1000,"wires":[["93f16891d794e03b"]]},{"id":"cb134e7c5a77d728","type":"inject","z":"5c1cfa6176e89b23","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"P2","payload":"7","payloadType":"num","x":250,"y":1040,"wires":[["93f16891d794e03b"]]},{"id":"e9111659cebc98f5","type":"change","z":"5c1cfa6176e89b23","name":"difference","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.P1-payload.P2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":1020,"wires":[["bf32970f8c0d987a"]]},{"id":"bf32970f8c0d987a","type":"debug","z":"5c1cfa6176e89b23","name":"debug 230","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":730,"y":1020,"wires":[]},{"id":"f9f8aa7f58db37fc","type":"debug","z":"5c1cfa6176e89b23","name":"debug 232","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":570,"y":1060,"wires":[]}]
From this, I learned that I have to set the "msg.topic" and continue with "key/value objects".
Unfortunately I was still not able to transfer this to my dashboard. I was able to enter the "topic" in the modbus-read node. I think, the settings in my buffer parser should also be ok, however it looks like I have still issues with my "convert & rounding" function.... The reason, why I want to use this is getting rid of the many decimal placeses (I want to write the values later in a sql-database)... If there is a better way, please let me know.
[{"id":"358902bd362de869","type":"group","z":"5c1cfa6176e89b23","name":"Test","style":{"label":true},"nodes":["84dd32dc7b3e9315","e2d73a893eba36cf","9c9667531623af10","9b8d97ddc575370a","6605234fe61afaf0","a24123c84780aed0","3eef6e0e5df04f6e","6ce3dbb2a89cbc54","853f3cdb4f2eb2ce","79023a40718d81ea","96167288014520bc","392a13672de977ff","8d5be842405e35a6","e52092998ed2162b","f02e3d60ec1f4f19","bf58219a946785a8","eb57d4e94eaf8dac","263c8750413781f5","5b426415769c6947","6c109de31061d391"],"x":74,"y":99,"w":1312,"h":382},{"id":"84dd32dc7b3e9315","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P1 (W)","topic":"P1","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"6","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"10","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":140,"wires":[["e2d73a893eba36cf"],[]]},{"id":"e2d73a893eba36cf","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"P1","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":140,"wires":[["263c8750413781f5","392a13672de977ff"]]},{"id":"9c9667531623af10","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":140,"wires":[]},{"id":"9b8d97ddc575370a","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P2 (W)","topic":"P2","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"255","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"10","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":240,"wires":[["6605234fe61afaf0"],[]]},{"id":"6605234fe61afaf0","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"P2","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":240,"wires":[["8d5be842405e35a6"]]},{"id":"a24123c84780aed0","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":240,"wires":[]},{"id":"3eef6e0e5df04f6e","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1+P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1270,"y":320,"wires":[]},{"id":"6ce3dbb2a89cbc54","type":"join","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":",","joinerType":"str","useparts":true,"accumulate":false,"timeout":"7","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":830,"y":320,"wires":[["5b426415769c6947"]]},{"id":"853f3cdb4f2eb2ce","type":"link in","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link in 1","links":[],"x":305,"y":420,"wires":[["96167288014520bc"]]},{"id":"79023a40718d81ea","type":"link out","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link out 1","mode":"return","links":[],"x":695,"y":420,"wires":[]},{"id":"96167288014520bc","type":"function","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"convert (W to kW) & rounding","func":"msg.payload = Math.round((msg.payload/1000) * 10) / 10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":420,"wires":[["79023a40718d81ea"]]},{"id":"392a13672de977ff","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":140,"wires":[["9c9667531623af10","6ce3dbb2a89cbc54","6c109de31061d391"]]},{"id":"8d5be842405e35a6","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":240,"wires":[["a24123c84780aed0","6ce3dbb2a89cbc54"]]},{"id":"e52092998ed2162b","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 93","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1240,"y":380,"wires":[]},{"id":"f02e3d60ec1f4f19","type":"change","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"sum","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum(payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":320,"wires":[["3eef6e0e5df04f6e","e52092998ed2162b"]]},{"id":"bf58219a946785a8","type":"change","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"substraction","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.P1-payload.P2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":440,"wires":[["eb57d4e94eaf8dac"]]},{"id":"eb57d4e94eaf8dac","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 231","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1250,"y":440,"wires":[]},{"id":"263c8750413781f5","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 235","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":550,"y":180,"wires":[]},{"id":"5b426415769c6947","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 237","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1030,"y":380,"wires":[]},{"id":"6c109de31061d391","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 238","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":830,"y":180,"wires":[]},{"id":"1fa6af670418434d","type":"modbus-client","name":"Trafo 7 Schneider","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"172.20.39.211","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"0","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true,"showWarnings":true,"showLogs":true},{"id":"a51173d2f89918d2","type":"ui_group","name":"Dashboard_Test","tab":"914279a7ba6a5984","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"914279a7ba6a5984","type":"ui_tab","name":"By_Dashboard","icon":"dashboard","disabled":false,"hidden":false}]
The most popular approach is to store actual (unmodified) values in your database & only format them for display. There are many reasons for this, but typically if you store lots of values over time and then try to summarise them & you have already removed decimal precision, your summations will be inaccurate.
thank you for this hint... you are definitively right...
in my case, the energy meters have an inacuracity of 1-5%... meaning most of the decimal precission is anyway useless information. In addtion the dashboard will contain many channels and not to overload the database, I prefer to continue with "rounding"
could you please give me a hint, how to adapt my "convert & rounding" function, so that it also passes throug the "msg.topic"?
Since your payload output from buffer parser is an object containing property P1 you cannot simply perform math operations on msg.payload (hence the NaN aka Not a Number)
Add debug nodes (set to show complete msg) to the output of your modbus nodes and capture some real data I can use to simulate your setup. See the bit about "copy value" below...
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path/value for any data item.
BX00Cy7yHi
Assuming that you are storing the values as numbers in the database then it won't make any difference how many decimal places you have. A number takes up the same amount of storage whatever value it is.
finally I made it... thansks to everybody supporting me on this... but I still need to practice a lot, to get familar with messages...
the settings in buffer-parser were wrong...
[{"id":"358902bd362de869","type":"group","z":"5c1cfa6176e89b23","name":"Test","style":{"label":true},"nodes":["84dd32dc7b3e9315","e2d73a893eba36cf","9c9667531623af10","9b8d97ddc575370a","6605234fe61afaf0","a24123c84780aed0","3eef6e0e5df04f6e","6ce3dbb2a89cbc54","853f3cdb4f2eb2ce","79023a40718d81ea","96167288014520bc","392a13672de977ff","8d5be842405e35a6","e52092998ed2162b","f02e3d60ec1f4f19","bf58219a946785a8","eb57d4e94eaf8dac","263c8750413781f5","5b426415769c6947","6c109de31061d391","3552cc98ca89fafa"],"x":74,"y":99,"w":1312,"h":382},{"id":"84dd32dc7b3e9315","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P1 (W)","topic":"P1","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"6","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"10","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":140,"wires":[["e2d73a893eba36cf","3552cc98ca89fafa"],[]]},{"id":"e2d73a893eba36cf","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"P1","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":140,"wires":[["263c8750413781f5","392a13672de977ff"]]},{"id":"9c9667531623af10","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":140,"wires":[]},{"id":"9b8d97ddc575370a","type":"modbus-read","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"Power P2 (W)","topic":"P2","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"showWarnings":true,"unitid":"255","dataType":"HoldingRegister","adr":"32077","quantity":"2","rate":"10","rateUnit":"s","delayOnStart":false,"startDelayTime":"","server":"1fa6af670418434d","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":190,"y":240,"wires":[["6605234fe61afaf0"],[]]},{"id":"6605234fe61afaf0","type":"buffer-parser","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"floatbe","name":"P2","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"return","multipleResult":true,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":370,"y":240,"wires":[["8d5be842405e35a6"]]},{"id":"a24123c84780aed0","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1260,"y":240,"wires":[]},{"id":"3eef6e0e5df04f6e","type":"ui_gauge","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","group":"a51173d2f89918d2","order":2,"width":"0","height":"0","gtype":"gage","title":"Power P1+P2 (kW)","label":"kW","format":"{{value}}","min":"0","max":"200","colors":["#00b500","#e6e600","#ca3838"],"seg1":"0","seg2":"100","diff":false,"className":"","x":1270,"y":320,"wires":[]},{"id":"6ce3dbb2a89cbc54","type":"join","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":",","joinerType":"str","useparts":true,"accumulate":false,"timeout":"7","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":830,"y":320,"wires":[["5b426415769c6947","f02e3d60ec1f4f19","bf58219a946785a8"]]},{"id":"853f3cdb4f2eb2ce","type":"link in","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link in 1","links":[],"x":305,"y":420,"wires":[["96167288014520bc"]]},{"id":"79023a40718d81ea","type":"link out","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"link out 1","mode":"return","links":[],"x":695,"y":420,"wires":[]},{"id":"96167288014520bc","type":"function","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"convert (W to kW) & rounding","func":"msg.payload = Math.round((msg.payload/1000) * 10) / 10;\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":420,"wires":[["79023a40718d81ea"]]},{"id":"392a13672de977ff","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":140,"wires":[["9c9667531623af10","6ce3dbb2a89cbc54","6c109de31061d391"]]},{"id":"8d5be842405e35a6","type":"link call","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"W to kW","links":["853f3cdb4f2eb2ce"],"linkType":"static","timeout":"30","x":640,"y":240,"wires":[["a24123c84780aed0","6ce3dbb2a89cbc54"]]},{"id":"e52092998ed2162b","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 93","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1240,"y":380,"wires":[]},{"id":"f02e3d60ec1f4f19","type":"change","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"sum","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.P1+payload.P2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":320,"wires":[["3eef6e0e5df04f6e","e52092998ed2162b"]]},{"id":"bf58219a946785a8","type":"change","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"substraction","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.P1-payload.P2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":440,"wires":[["eb57d4e94eaf8dac"]]},{"id":"eb57d4e94eaf8dac","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 231","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1250,"y":440,"wires":[]},{"id":"263c8750413781f5","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 235","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":550,"y":180,"wires":[]},{"id":"5b426415769c6947","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 237","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1030,"y":380,"wires":[]},{"id":"6c109de31061d391","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 238","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":830,"y":180,"wires":[]},{"id":"3552cc98ca89fafa","type":"debug","z":"5c1cfa6176e89b23","g":"358902bd362de869","name":"debug 239","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":370,"y":180,"wires":[]},{"id":"1fa6af670418434d","type":"modbus-client","name":"Trafo 7 Schneider","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"failureLogEnabled":true,"tcpHost":"172.20.39.211","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"0x3A","unit_id":"0","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true,"showWarnings":true,"showLogs":true},{"id":"a51173d2f89918d2","type":"ui_group","name":"Dashboard_Test","tab":"914279a7ba6a5984","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"914279a7ba6a5984","type":"ui_tab","name":"By_Dashboard","icon":"dashboard","disabled":false,"hidden":false}]
I will also rethink, if rounding is necessary...
