During my MQTT fun project, I'm working with bit patterns so it would be nice to be able to use a change node to do this
but it doesn't work (for valid reasons)
I can achieve it using a function node
but that's always my tool of last resort
Is it possible to do with some simple JSONata within the change node?
Or another way?
you can use 0x rather than 0b ... eg
which while not as easy as binary for bit masks is somewhat easier than decimal
Sticking quotes around the value works for binary as well
Hmm... but doesn't display correctly in the expanded buffer editor page.. whereas the hex does...
PR Raised - fix buffer viewer to handle 0b style binary by dceejay · Pull Request #4393 · node-red/node-red · GitHub
