Hi all,
I'm migrating my Node-RED deployment from systemd to Docker Compose, and I'm running into an issue with environment variables.
Previously, when using systemctl, I used an EnvironmentFile=/etc/nodered/.env in my service unit. This allowed me to access environment variables directly in Node-RED via env.get("MY_VAR") inside function nodes.
Now, in my Docker Compose setup, I have:
services:
app:
image: ${IMAGE}
env_file:
- ../../.env
environment:
- NODE_RED_CREDENTIAL_SECRET=${NODE_RED_CREDENTIAL_SECRET}
I verified with docker compose config that the variables are injected correctly into the container. But when I use env.get("MY_VAR"), it returns "".
Is there a way to make env.get() work with environment variables passed via Docker (like it did with systemd)? I have over 20 environment variables, so manually declaring each one in settings.js feels quite unmaintainable. The simplest and most scalable solution for me is to use a .env file and access variables using env.get() as before.
Is there any recommended way to make env.get() work with variables from Docker’s env_file, similar to how it worked with systemd's EnvironmentFile?
Thank you!
