I've been building a sub-node to control lights in my home.
The sub-node is working as it should now, but I'm getting the following error on the debug window every time I deploy it after a change:
12/30/2024, 8:42:46 AMmsg : string[54]
"Error delivering message to node:undefined [undefined]"
12/30/2024, 8:42:46 AMmsg : string[316]
string[316]
TypeError: sendEvent.destination.node.receive is not a function
at deliverMessageToDestination (/opt/node_modules/@node-red/runtime/lib/flows/Flow.js:803:40)
at Immediate._onImmediate (/opt/node_modules/@node-red/runtime/lib/flows/Flow.js:819:21)
at process.processImmediate (node:internal/timers:476:21)
12/30/2024, 8:42:47 AMmsg : string[316]
string[316]
12/30/2024, 8:42:47 AMmsg : string[54]
string[316]
As you can see, the same error is shown three times. At first it was shown only once, but as I've been working on the sub-node, more errors are shown at the time of deployment.
At first, I ignored the messages as the sub-node was working as it should, but as I'm trying to optimize the sub-node and add more features, I am getting weird behavior in some of the nodes inside the sub-node, leading to unexpected results. For example, in this portion of the sub-node:
The sun-position node should give the information on when the sunset, sunrise, dawn, dusk, etc. should happen today, and then the Custom Evening End Time node adds a custom evening end time to the message. The weird thing is that the custom evening end time information is being sent by sun-position node when it haven't been added to the message by Custom Evening End Time node yet.
Not sure if this weird behavior is related to the error messages but I would like to solve the errors before continuing troubleshooting any other issue. So here I am asking for some guidance on how to tackle those error messages. Any advice with be greatly appreciated.
