I was trying to follow the instruction at Interacting with Arduino : Node-RED to interface arduino with node-red. Until now, I've installed node-red, and loaded the firmata firmware on the board.
When I'm trying to install node-red-node-arduino using npm install node-red-node-arduino in the .node-red directory, I get build errors.
Node-red and NPM version:
30 Sep 20:49:43 - [info] Node-RED version: v2.0.6
30 Sep 20:49:43 - [info] Node.js version: v12.14.0
30 Sep 20:49:43 - [info] Windows_NT 10.0.19043 x64 LE
The error message is:
npm ERR! code 1
npm ERR! path C:\Users\kumar\.node-red\node_modules\@serialport\bindings
npm ERR! command failed
npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! Building the projects in this solution one at a time. To enable parallel build, please add the "-m" switch.
npm ERR! serialport.cpp
npm ERR! serialport_win.cpp
npm ERR! win_delay_load_hook.cc
npm ERR! C:\\Users\\kumar\\AppData\\Local\\node-gyp\\Cache\\12.14.0\\x64\\node.lib : fatal error LNK1107: invalid or corrupt file: cannot read at 0x4B662D [C:\Users\kumar\.node-red\node_modules\@serialport\bindings\build\bindings.vcxproj]
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@7.1.2
npm ERR! gyp info using node@12.14.0 | win32 | x64
npm ERR! gyp info find Python using Python version 3.9.7 found at "C:\Users\kumar\AppData\Local\Programs\Python\Python39-64\python.exe"
npm ERR! gyp info find VS using VS2019 (16.10.31410.357) found at:
npm ERR! gyp info find VS "C:\Program Files (x86)\Microsoft Visual Studio\2019\Community"
npm ERR! gyp info find VS run with --verbose for detailed information
npm ERR! gyp info spawn C:\Users\kumar\AppData\Local\Programs\Python\Python39-64\python.exe
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args 'C:\\Users\\kumar\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\gyp\\gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'msvs',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args 'C:\\Users\\kumar\\.node-red\\node_modules\\@serialport\\bindings\\build\\config.gypi',
npm ERR! gyp info spawn args 'C:\\Users\\kumar\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\addon.gypi',
npm ERR! gyp info spawn args 'C:\\Users\\kumar\\AppData\\Local\\node-gyp\\Cache\\12.14.0\\include\\node\\common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=C:\\Users\\kumar\\AppData\\Local\\node-gyp\\Cache\\12.14.0',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=C:\\Users\\kumar\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=C:\\\\Users\\\\kumar\\\\AppData\\\\Local\\\\node-gyp\\\\Cache\\\\12.14.0\\\\<(target_arch)\\\\node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=C:\\Users\\kumar\\.node-red\\node_modules\\@serialport\\bindings',
npm ERR! gyp info spawn args '-Dnode_engine=v8',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'C:\\Users\\kumar\\.node-red\\node_modules\\@serialport\\bindings\\build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\MSBuild.exe
npm ERR! gyp info spawn args 'build/binding.sln',
npm ERR! gyp info spawn args '/clp:Verbosity=minimal',
npm ERR! gyp info spawn args '/nologo',
npm ERR! gyp info spawn args '/p:Configuration=Release;Platform=x64'
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Current\Bin\MSBuild.exe` failed with exit code: 1
npm ERR! gyp ERR! stack at ChildProcess.onExit (C:\Users\kumar\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (events.js:210:5)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:272:12)
npm ERR! gyp ERR! System Windows_NT 10.0.19043
npm ERR! gyp ERR! command "D:\\software installation\\nodejs\\node.exe" "C:\\Users\\kumar\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
npm ERR! gyp ERR! cwd C:\Users\kumar\.node-red\node_modules\@serialport\bindings
npm ERR! gyp ERR! node -v v12.14.0
npm ERR! gyp ERR! node-gyp -v v7.1.2
npm ERR! gyp ERR! not ok
npm ERR! C:\Users\kumar\AppData\Local\npm-cache\_logs\2021-09-30T15_15_32_459Z-debug.log
I didn't have any other serial window or arduino ide windows open. Also, I've msvc c++ build chain installed.
What is the problem and how can I fix it?
