i have started using the Projects feature and it all works, except that i'm getting these "warning signs" on some packages.
When i click on "install" on one of them, i get the following:
2022-10-01T15:25:03.223Z Installieren : color-temperature ~0.2.7
2022-10-01T15:25:03.266Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict color-temperature@~0.2.7
2022-10-01T15:25:04.415Z [err] npm
2022-10-01T15:25:04.416Z [err] WARN
2022-10-01T15:25:04.416Z [err] config production Use `--omit=dev` instead.
2022-10-01T15:25:06.879Z [out]
2022-10-01T15:25:06.879Z [out] up to date in 3s
2022-10-01T15:25:06.901Z rc=0
The installation then fails but the module (which is actually installed and up-to-date) works just as expected.
How can i fix this?
I already tried installing the modules manually using the shell (i'm on a Raspberry pi 4 2GB with Raspbian Bullseye installed and NodeRed set up using the official install script), but it didn't help.
Thanks,
Aaron
