[error] [ThingspeakSendSimple:1090896] Got 400
I get this every time I start Node-RED. I cant delete this node because it says it's in use but it's not in any active flow. How do I stop this?
Thanks :slight_smile:
your credentials.
29 Jun 11:54:20 - [info] Starting flows
29 Jun 11:54:20 - [info] Started flows
29 Jun 11:54:20 - [info] Server now running at http://127.0.0.1:1880/
29 Jun 11:54:27 - [error] [ThingspeakSendSimple:1090896] Got 400
29 Jun 11:54:31 - [error] [ThingspeakSendSimple:1090896] Got 400
29 Jun 11:54:36 - [error] [ThingspeakSendSimple:1090896] Got 400
29 Jun 11:54:41 - [error] [ThingspeakSendSimple:1090896] Got 400
29 Jun 11:54:48 - [error] [ThingspeakSendSimple:1090896] Got 400
29 Jun 11:54:53 - [error] [ThingspeakSendSimple:1090896] Got 400
29 Jun 11:54:58 - [error] [ThingspeakSendSimple:1090896] Got 400
You can't delete the module because you must have a ThingSpeak node somewhere in your flows.
Have you searched for it (Ctrl-F in the editor)? It could be a configuration node - open up the config node sidebar to see if its listed there.
Ah.. yes it was! Thanks knolleary, much appreciated :slight_smile:
