Hi!
HW Raspberry Pi 3 Model B V1,2
Image Rasbian Buster Lite
I tried to install node-red-dashboard using manage palette but i it fails.
Error log
0 info it worked if it ends with ok
1 verbose cli [
1 verbose cli '/usr/bin/node',
1 verbose cli '/usr/bin/npm',
1 verbose cli 'install',
1 verbose cli '--no-audit',
1 verbose cli '--no-update-notifier',
1 verbose cli '--save',
1 verbose cli '--save-prefix="~"',
1 verbose cli '--production',
1 verbose cli 'node-red-dashboard@2.19.2'
1 verbose cli ]
2 info using npm@6.13.4
3 info using node@v12.13.1
4 verbose stack /usr/lib/node_modules/npm/node_modules/stream-each/index.js:1
4 verbose stack ��~G��Eİ@������A?��A7��~G��:İ@�����B��A?��AW��~G��.�%^C�^C
4 verbose stack
4 verbose stack
4 verbose stack SyntaxError: Invalid or unexpected token
4 verbose stack at Module._compile (internal/modules/cjs/loader.js:895:18)
4 verbose stack at Object.Module._extensions..js (internal/modules/cjs/loader.js:995:10)
4 verbose stack at Module.load (internal/modules/cjs/loader.js:815:32)
4 verbose stack at Function.Module._load (internal/modules/cjs/loader.js:727:14)
4 verbose stack at Module.require (internal/modules/cjs/loader.js:852:19)
4 verbose stack at require (internal/modules/cjs/helpers.js:74:18)
4 verbose stack at Object. (/usr/lib/node_modules/npm/node_modules/mississippi/index.js:2:23)
4 verbose stack at Module._compile (internal/modules/cjs/loader.js:959:30)
4 verbose stack at Object. (/usr/lib/node_modules/npm/node_modules/cacache/lib/entry-index.js:11:12)
5 verbose cwd /home/pi/.node-red
6 verbose Linux 4.19.75-v7+
7 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "--no-audit" "--no-update-notifier" "--save" "--save-prefix="~"" "--production" "node-red-dashboard@2.19.2"
8 verbose node v12.13.1
9 verbose npm v6.13.4
10 error Invalid or unexpected token
