Can someone help to get this sorted out?
msg.payload= {
"body": {
"roomId": "Y2lzY29zcGFyazovL3VzL1JPT00vMmEzYzRjMDAtNTliOC0xMWU5LWEzZjktNGRjNmI1MmU3MTE3", "text": Network Device Details: '\n' Device 1: Host Name- "+host0+" , Management IP- "+host0IP+" , Reachability Status- "+host0S+"
below screenshot list the errors i'm getting
if you are posting code it is far easier to read if you format it, please follow the advice in this post: How to share code or flow json
The following is incorrect. Look at the quotes...
compared to...
"text": "Network Device Details: '\n' Device 1: Host Name- "+host0+" , Management IP- "+host0IP+" , Reachability Status- "+host0S+"
assuming host0 host 0IP and host0S are variables?
yes they are variables,
var host0 = msg.payload.response[0].hostname;
var host0IP = msg.payload.response[0].managementIpAddress;
var host0S = msg.payload.response[0].reachabilityStatus;
Thanks a lot, i sorted that out
