EspEasy Data filter
I use MQTT from domoticz afther this i put a filter on it to select the IDX fot the right data
When i debug it i got something like this.
{ idx: 350, RSSI: 7, nvalue: 0, svalue: "237.90;0.00;0.00;0.00" }
But now i onely want one value eg the first value.
In a function node i use this
msg.payload = msg.payload.svalue1;
but, i get no result the debug window says "undefined"
Can someone please help me
Where does the 1 in svalue1 come from?
It does not exist in your example data. svalue1 is therefore undefined.
I can only assume that you want the first number in the list attached to svalue.
That can be achieved like this:
msg.payload = msg.payload.svalue.split(";")[0];
Or in JSONata:
$split($.svalue,";")[0]
When i use this i dont get a result from the filter
When i use the next filter i got a result
This is the value what is sent via ESPEasy to MQTT
What number do you want?
or
Thanks man this did the job for me,i not a specialist in nod red but you just make my day, thank you very much
The value between the ;
I got this here and this do the work for me
msg.payload = msg.payload.svalue.split(";")[2];
Hey guys thanks for the fast help
you make me happy
thanks
Here are two other methods to get to the string data of svalue and convert to numbers.
[{"id":"201db681adfdfa53","type":"inject","z":"bf622e623503117a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"idx\":350,\"RSSI\":7,\"nvalue\":0,\"svalue\":\"237.90;0.00;0.00;0.00\"}","payloadType":"json","x":310,"y":400,"wires":[["3ade2f7a493c697e","7ab80f2abcc19433"]]},{"id":"3ade2f7a493c697e","type":"change","z":"bf622e623503117a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.svalue","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":460,"y":400,"wires":[["1e6fc38adb5cf6cf"]]},{"id":"7ab80f2abcc19433","type":"change","z":"bf622e623503117a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number($substringBefore($$.payload.svalue, \";\"))","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":460,"wires":[["a54e479046a9a022"]]},{"id":"1e6fc38adb5cf6cf","type":"csv","z":"bf622e623503117a","name":"","sep":";","hdrin":"","hdrout":"none","multi":"one","ret":"\\n","temp":"name,another_anme,yet_another","skip":"0","strings":true,"include_empty_strings":"","include_null_values":"","x":610,"y":400,"wires":[["9fec9f2af5cfda9b"]]},{"id":"a54e479046a9a022","type":"debug","z":"bf622e623503117a","name":"debug 264","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":460,"wires":[]},{"id":"9fec9f2af5cfda9b","type":"debug","z":"bf622e623503117a","name":"debug 6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":740,"y":400,"wires":[]}]
The csv method requires no coding.
