Example needed for context menu
I just started playing with the SVG nodes and context menu.
I would like to know if there is anyway i can fill the label field in the following image to display something i pass from another node.
Sadly, this is what i am getting.
Can someone help me with displaying a custom label from another node??
checkout the readme, built in help and the built in examples (CTRL-I) - it shows you how to generate dynamic entries
I have gone through it but i get this error
It looks like i am doing something wrong :frowning:
is that a function node? a template mode? Which example did you try?
Sorry for the delay. I would like to have the programmed with a function node.
I am not sure how to address that label in the contextmenu (from a function node) as shown in the last image on the original post :frowning:
I asked if it was a function node because you have simply put an array in it with without doing anything with it.
Try this in your function node...
msg.menu = [
        "text": msg.payload[0].ParkingSlot,
        "icon": "fa-car",
        "enabled": true,
        "topic": "ParkingSlot",
        "payload": msg.payload[0].ParkingSlot,
        "payloadType": "str"
        "text": msg.payload[0].CarNoPlate,
        "icon": "fa-text-width",
        "enabled": true,
        "topic": "CarNoPlate",
        "payload": msg.payload[0].CarNoPlate,
Connect as follows...
your data payload --> function node --> menu node
