Examples for read multiple values from OPCUA server with function node through node-red-contrib-opcua
complete example for read multiple values from OPCUA server with function node-through node-red-contrib-opcua module
Hi there!
Here is a complete example for READ-MULTIPLE mode of a OPC UA Client node from node-red-contrib-opcua.
This example is taken from a section of a complete IIoT system I developed. I made it quite robust by adding a fallback mechanism in case of failures — but of course, you can use only the parts you need and remove the fallback logic (which involves the 'linkIn', 'linkOut' nodes and the 'areNodeIdsStored' variable).
        "id": "a07113ad99ef2c6f",
        "type": "group",
        "z": "521893e30bf3a45c",
        "name": "Client READ-MULTIPLE",
        "style": {
            "label": true,
            "stroke": "#0070c0",
            "fill": "#0070c0",
            "fill-opacity": "0.1",
            "color": "#000000",
            "label-position": "n"
        "nodes": [
            "a3ebbfea1281b7dd",
            "dbc58fbb4b1a16b0",
            "9c9d996d104812c2",
            "b58839d38bec2747",
            "cb3c845452788b5f",
            "6a1304589666c6b8",
            "bc1dd60b6f0e60e8",
            "777bfd51dab63c6a",
            "7d4c5a82a267599c",
            "0c0c5e44cb7ac40b",
            "1f8f9c895eba953a",
            "0f649565db5398cf",
            "68072338f325f046",
            "f0d4ef6807685e3e",
            "c879bc714d85e3c0",
            "48eca354f6767036",
            "57dabcc722d5c830",
            "d9b6eec4bb841b9b",
            "1825f0fa1828f615",
            "3f4d923cca1abe78"
        "x": 134,
        "y": 571.8571510314941,
        "w": 1572,
        "h": 369.14284896850586
        "id": "a3ebbfea1281b7dd",
        "type": "OpcUa-Client",
        "g": "a07113ad99ef2c6f",
        "endpoint": "5054e70d33a31e8f",
        "action": "readmultiple",
        "deadbandtype": "a",
        "deadbandvalue": 1,
        "time": 10,
        "timeUnit": "s",
        "certificate": "n",
        "localfile": "",
        "localkeyfile": "",
        "securitymode": "None",
        "securitypolicy": "None",
        "useTransport": false,
        "maxChunkCount": 1,
        "maxMessageSize": 8192,
        "receiveBufferSize": 8192,
        "sendBufferSize": 8192,
        "setstatusandtime": false,
        "keepsessionalive": false,
        "x": 940,
        "y": 740,
                "6a1304589666c6b8"
                "dbc58fbb4b1a16b0"
        "id": "dbc58fbb4b1a16b0",
        "type": "switch",
        "property": "status",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "no items to read",
                "vt": "str"
                "t": "eq",
                "v": "nodeId stored",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1150,
        "y": 760,
                "b58839d38bec2747"
                "9c9d996d104812c2"
        "id": "9c9d996d104812c2",
        "type": "change",
        "name": "Ok",
        "rules": [
                "t": "set",
                "p": "areNodeIdsStored",
                "pt": "flow",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1330,
        "y": 780,
        "id": "b58839d38bec2747",
        "type": "change",
        "name": "Error (try again)",
        "rules": [
                "t": "set",
                "pt": "flow",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1360,
        "y": 740,
                "cb3c845452788b5f"
        "id": "cb3c845452788b5f",
        "type": "link out",
        "name": "OPC UA Client [Error-NoNodeIdsRegistered]",
        "mode": "link",
        "links": [
            "f0d4ef6807685e3e"
        "x": 1535,
        "y": 740,
        "id": "6a1304589666c6b8",
        "type": "switch",
        "name": "statusCode == OK",
        "property": "statusCode.value",
        "rules": [
                "t": "eq",
                "v": "0",
                "vt": "num"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 1170,
        "y": 700,
                "3f4d923cca1abe78"
        "id": "bc1dd60b6f0e60e8",
        "type": "OpcUa-Item",
        "item": "ns=6;i=492060",
        "datatype": "Byte",
        "value": "",
        "name": "NodeId1",
        "x": 700,
        "y": 680,
                "a3ebbfea1281b7dd"
        "id": "777bfd51dab63c6a",
        "item": "ns=6;i=426524",
        "datatype": "Byte",
        "value": "",
        "name": "NodeId2",
        "x": 700,
        "y": 720,
                "a3ebbfea1281b7dd"
        "id": "7d4c5a82a267599c",
        "item": "ns=6;i=229916",
        "datatype": "Byte",
        "value": "",
        "name": "NodeId3",
        "x": 700,
        "y": 760,
                "a3ebbfea1281b7dd"
        "id": "0c0c5e44cb7ac40b",
        "item": "ns=6;i=164380",
        "datatype": "Byte Array",
        "value": "",
        "name": "NodeId4",
        "x": 700,
        "y": 800,
                "a3ebbfea1281b7dd"
        "id": "1f8f9c895eba953a",
        "type": "inject",
        "name": "Inject NodeIds (initialization)",
        "props": [],
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": "1",
        "topic": "",
        "x": 300,
        "y": 720,
                "0c0c5e44cb7ac40b",
                "7d4c5a82a267599c",
                "777bfd51dab63c6a",
                "bc1dd60b6f0e60e8"
        "id": "0f649565db5398cf",
        "type": "inject",
        "name": "[debug] Read all",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "readmultiple",
        "x": 660,
        "y": 900,
                "a3ebbfea1281b7dd"
        "id": "68072338f325f046",
        "type": "inject",
        "name": "[debug] Clear",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "clearitems",
        "x": 660,
        "y": 860,
                "a3ebbfea1281b7dd"
        "id": "f0d4ef6807685e3e",
        "type": "link in",
        "name": "OPC UA Client [Register NodeIds]",
        "links": [
            "57dabcc722d5c830",
            "cb3c845452788b5f"
        "x": 255,
        "y": 780,
                "48eca354f6767036"
        "id": "c879bc714d85e3c0",
        "type": "comment",
        "name": "About \"NodeIds\" (click me)",
        "info": "## OPC UA - NodeId (Node Identifier)\n\nIn **OPC UA**, a **NodeId** uniquely identifies a node (e.g., variable, object, method) in the server’s **Address Space**.\n\n## NodeId Structure\n- **Namespace Index (ns):** Distinguishes identifiers from different domains.\n- **Identifier Type:** Can be one of the following:\n  - Numeric (`i=`)\n  - String (`s=`)\n  - GUID (`g=`)\n  - ByteString (`b=`)\n- **Identifier:** The actual value that identifies the node.\n\n## Examples\n- `ns=2;i=1234` → Numeric\n- `ns=1;s=Motor1.Status` → String\n- `ns=3;g=550e8400-e29b-41d4-a716-446655440000` → GUID\n- `ns=4;b=QmFzZTY0` → ByteString\n\n## Purpose\n- Allows clients to access:\n  - Variables\n  - Methods\n  - Objects\n  - Folders\n- Used in operations like `Read`, `Write`, `Browse`, and `Call`.\n\n> To find the data and corresponding NodeIds, I recommend using the 'UA Expert' software to connect and browse your OPC UA server.",
        "x": 410,
        "y": 840,
        "wires": [],
        "icon": "font-awesome/fa-info-circle"
        "id": "48eca354f6767036",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "3",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 360,
        "y": 780,
                "7d4c5a82a267599c",
                "bc1dd60b6f0e60e8",
                "777bfd51dab63c6a",
                "0c0c5e44cb7ac40b"
        "id": "57dabcc722d5c830",
        "type": "link out",
        "name": "Fallback [Re-Inject NodeIds]",
        "mode": "link",
        "links": [
            "f0d4ef6807685e3e"
        "x": 825.0000171661377,
        "y": 612.8571510314941,
        "id": "d9b6eec4bb841b9b",
        "type": "switch",
        "name": "are NodeIds Stored?",
        "property": "areNodeIdsStored",
        "propertyType": "flow",
        "rules": [
                "t": "false"
                "t": "true"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 640,
        "y": 620,
                "57dabcc722d5c830"
                "a3ebbfea1281b7dd"
        "id": "1825f0fa1828f615",
        "type": "inject",
        "name": "Read Data 1x/minute",
        "props": [],
        "repeat": "60",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 320,
        "y": 620,
                "d9b6eec4bb841b9b"
        "id": "3f4d923cca1abe78",
        "type": "debug",
        "name": "your data should appear here if everything is ok",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 1480,
        "y": 700,
        "id": "5054e70d33a31e8f",
        "type": "OpcUa-Endpoint",
        "endpoint": "opc.tcp://192.168.0.50:4840",
        "secpol": "None",
        "secmode": "None",
        "none": true,
        "login": false,
        "usercert": false,
        "usercertificate": "",
        "userprivatekey": ""
Also read the official page of node-red-contrib-opcua module, they have a lot of usage examples there.
Hope this helps you ^^
