Hi!
I installed the uibuilder to use apexcharts in node red, but when I try to implement the example on node red, I only get the title, no the chart. The example is this.
Hi!
I have just tested that code with the latest version of node-red and it appears to be working fine. Can you please share your html and js code?
Yes, here is the js code:
Vue.component('apexchart', VueApexCharts)
// eslint-disable-next-line no-unused-vars
var app1 = new Vue({
el: '#app',
data: {
startMsg : 'Vue has started, waiting for messages',
// Data for bar chart
options: {
chart: {
xaxis: {
categories: [1991, 1992, 1993, 1994, 1995, 1996, 1997, 1998]
series: [{
data: [30, 40, 45, 50, 49, 60, 70, 91]
// Data for donut chart
doptions: {},
dseries: [44, 55, 41, 17, 15]
}, // --- End of data --- //
computed: {
}, // --- End of computed --- //
methods: {
}, // --- End of methods --- //
// Available hooks: init,mounted,updated,destroyed
mounted: function(){
/** **REQUIRED** Start uibuilder comms with Node-RED @since v2.0.0-dev3
* Pass the namespace and ioPath variables if hosting page is not in the instance root folder
* e.g. If you get continual `uibuilderfe:ioSetup: SOCKET CONNECT ERROR` error messages.
* e.g. uibuilder.start('/nr/uib', '/nr/uibuilder/vendor/socket.io') // change to use your paths/names
uibuilder.start()
var vueApp = this
// Process new messages from Node-RED
uibuilder.onChange('msg', function (newVal) {
if ( typeof newVal.payload === 'number' ){
// Add new element
vueApp.dseries.push(newVal.payload)
// Lose the first element
vueApp.dseries.shift()
//console.log(vueApp.dseries)
} // --- End of mounted hook --- //
}) // --- End of app1 --- //
// EOF
and this is the html code:
<!doctype html><html lang="en"><head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=yes">
<title>ApexChart/VueJS Example - Node-RED UI Builder</title>
<meta name="description" content="Node-RED UI Builder - ApexChart/VueJS Example">
<link rel="icon" href="./images/node-blue.ico">
<link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap/dist/css/bootstrap.min.css" />
<link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.css" />
<link rel="stylesheet" href="./index.css" media="all">
</head><body>
<div id="app">
<b-container id="app_container">
<h1>
Examples of using <a href="https://apexcharts.com/docs/vue-charts/" target="_blank">ApexChart</a>
with uibuilder, VueJS and bootstrap-vue
</h1>
<b-row>
<b-card col class="w-50" header="Bar Chart" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
<apexchart width="100%" type="bar" :options="options" :series="series"></apexchart>
</b-card>
<b-card col class="w-50" header="Donut Chart" border-variant="primary" header-bg-variant="primary" header-text-variant="white" align="center">
<apexchart width="100%" type="donut" :options="doptions" :series="dseries"></apexchart>
</b-card>
</b-row>
</b-container>
</div>
<script src="../uibuilder/vendor/socket.io/socket.io.js"></script>
<script src="../uibuilder/vendor/vue/dist/vue.min.js"></script>
<script src="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.js"></script>
<!-- Loading from CDN, use uibuilder to install packages and change to vendor links -->
<script src="https://cdn.jsdelivr.net/npm/apexcharts"></script>
<script src="https://cdn.jsdelivr.net/npm/vue-apexcharts"></script>
<script src="./uibuilderfe.min.js"></script> <!-- //prod version -->
<script src="./index.js"></script>
</body></html>
I only get this on the chart page:
OK, you should check your browser's dev console for errors. As Andy has suggested, I suspect you've loaded Vue v3 rather than v2 and the fact that your browser window hasn't centred the title with a white background shows that bootstrap-vue is not loaded.
