Hello All,
I'm trying to execute command from nodered exec node.
This specific command only need admin right.
Any alternative to execute admin level commands from nodered?
Hello All,
Maybe you can share what command you try to use.
Security settings of this command can maybe be altered so no admin right are necessary.
Hi @edje11
Command is manage-bde -lock D: -ForceDismount
it's used to lock bitlocker enabled drive
Any changes to bitlocker MUST require admin rights. Anything else would be a serious security flaw.
If the PC is part of a managed service (e.g. InTune) or a member of a Windows domain, you should do this via a remote command using a service or account with domain privileges.
There are also PowerShell commands for controlling bitlocker but I'm pretty sure they will also need admin privalages.
This need exploration!
Thanks @TotallyInformation
