Extract from array ,object
Need some help to extract form an Object
2/16/2024, 10:20:06 AM[node: debug 90](http://127.0.0.1:1880/#)
msg.payload : array[1]
array[1]
0: object
intemp: "81.1"
unit: "F"
inhumi: "38%"
abs: "29.95 inHg"
rel: "29.95 inHg"
Need to extract the values for intemo,inhumi,abs,arel
individual to display as a text.
        "id": "7da2e023f84a2dcc",
        "type": "inject",
        "z": "f464957002a4d7f4",
        "props": [
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 130,
        "y": 140,
                "38dcf0f25307b8ab"
        "id": "38dcf0f25307b8ab",
        "type": "http request",
        "method": "GET",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "http://10.0.4.54/get_livedata_info?",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 290,
        "y": 240,
                "3bc27ec8fbe07fca"
        "id": "3bc27ec8fbe07fca",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "arraySpltType": "len",
        "stream": false,
        "addname": "",
        "x": 470,
        "y": 220,
                "3e2fe869e378fa50",
                "bd2a9c7d2f5272ea"
        "id": "3e2fe869e378fa50",
        "type": "debug",
        "name": "debug 90",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 660,
        "y": 160,
        "id": "a0da53b7dd6d2f89",
        "type": "ui_text",
        "group": "241820d172e65d1d",
        "order": 22,
        "width": 0,
        "height": 0,
        "label": "text",
        "format": "{{msg.payload[0].intemp}}",
        "layout": "row-spread",
        "className": "",
        "style": false,
        "font": "",
        "fontSize": 16,
        "color": "#000000",
        "x": 890,
        "y": 180,
        "id": "bd2a9c7d2f5272ea",
        "type": "function",
        "name": "function 15",
        "func": "msg.payload.intemp\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 670,
        "y": 220,
                "a0da53b7dd6d2f89"
        "id": "241820d172e65d1d",
        "type": "ui_group",
        "name": "MAIN POWER",
        "tab": "76c1d76e82d63ff5",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "76c1d76e82d63ff5",
        "type": "ui_tab",
        "name": "OBS",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
This Is what I am working on
Hi, i have updated your post for readability and to prevent the forum making your flow un-importable.
In future, please use the copy value button to copy good format data from messages and payloads - shown when you over hover a debug message property in the sidebar.
BX00Cy7yHi
Also, always wrap data/code/flows/logs in a code block
code here between three backticks
I'm not convinced that you need the split node.
Move your debug node to the output of your http request. Then, as @Steve-Mcl shows, you can find the path to the element[s] you want.
I think, for example, temperature is at msg.payload[0].intemp
In your function node you have this
msg.payload.intemp
Just the name of element msg.payload.intemp, even if it exists, does nothing with it.
Could it be that you wanted something like this? (Look, no functions!)
Are the Change nodes even needed, You could just use {{msg.payload[0].intemp}} or {{msg.payload[0].inhumi}} in the text nodes.
But as jbudd says, show the output of the http request node, so we can all be sure of the exact data.
Nope, change nodes not needed. Mind you, my illustration would be less self explanatory without them!
Debatable, you could name the text nodes similarly to the way you did with the change nodes.
If i'd have thunk of that i'd have dun it! :worried:
Thansk to all I was close, but your knowledge is super
jbudd
I add another sensor and now I received this object, Can you Please help me out to be able to display object 4,5,6,7. Thanks In advance for your time
/16/2024, 12:25:35 PMnode: debug 90
msg.payload : array[10]
array[10]
0: object
1: object
2: object
3: object
4: object
val: "0.00 mph"
5: object
val: "0.00 mph"
6: object
val: "17.22 mph"
7: object
val: "2.21 W/m2"
As i said before...
Sorry, I think now that I may get what you said.Let me know is this is good.
  {"id":"0x02","val":"--.-","unit":"F"},
  {"id":"0x07","val":"--"},
  {"id":"3","val":"--.-","unit":"F"},
  {"id":"0x03","val":"--.-","unit":"F"},
  {"id":"0x0B","val":"0.00 mph"},
  {"id":"0x0C","val":"0.00 mph"},
  {"id":"0x19","val":"17.22 mph"},
  {"id":"0x15","val":"1.74 W/m2"},
  {"id":"0x17","val":"0"},
  {"id":"0x0A","val":"228","battery":"5"}
I copy the value of the object, or I need to do it individual like this
Luis RIvera
Admin edit: wrap code in ``` code block ```
I thought we had given you sound advice before.
Two possible routes depending on if the array of object always has the same order.
I think you would gain some more insight into node-red if you watched these essentials videos
Example flows
[{"id":"1b77de4539b79cb2","type":"debug","z":"d1395164b4eec73e","name":"msg.payload.val","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload.val","targetType":"msg","statusVal":"payload","statusType":"auto","x":820,"y":5460,"wires":[]},{"id":"e8f3faaab5afb0df","type":"split","z":"d1395164b4eec73e","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":550,"y":5340,"wires":[["ad03663e3fc51aa7"]]},{"id":"54e60a80d26d8c2b","type":"inject","z":"d1395164b4eec73e","name":"if order can be different","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"id\":\"0x03\",\"val\":\"--.-\",\"unit\":\"F\"},{\"id\":\"0x0B\",\"val\":\"0.00 mph\"},{\"id\":\"0x0C\",\"val\":\"0.00 mph\"},{\"id\":\"0x19\",\"val\":\"17.22 mph\"},{\"id\":\"0x15\",\"val\":\"1.74 W/m2\"},{\"id\":\"0x02\",\"val\":\"--.-\",\"unit\":\"F\"},{\"id\":\"0x07\",\"val\":\"--\"},{\"id\":\"3\",\"val\":\"--.-\",\"unit\":\"F\"},{\"id\":\"0x17\",\"val\":\"0\"},{\"id\":\"0x0A\",\"val\":\"228\",\"battery\":\"5\"}]","payloadType":"json","x":380,"y":5340,"wires":[["e8f3faaab5afb0df"]]},{"id":"e42d18a01a6e78b5","type":"inject","z":"d1395164b4eec73e","name":"Array order always the same","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[   {\"id\":\"0x02\",\"val\":\"--.-\",\"unit\":\"F\"},   {\"id\":\"0x07\",\"val\":\"--\"},   {\"id\":\"3\",\"val\":\"--.-\",\"unit\":\"F\"},   {\"id\":\"0x03\",\"val\":\"--.-\",\"unit\":\"F\"},   {\"id\":\"0x0B\",\"val\":\"0.00 mph\"},   {\"id\":\"0x0C\",\"val\":\"0.00 mph\"},   {\"id\":\"0x19\",\"val\":\"17.22 mph\"},   {\"id\":\"0x15\",\"val\":\"1.74 W/m2\"},   {\"id\":\"0x17\",\"val\":\"0\"},   {\"id\":\"0x0A\",\"val\":\"228\",\"battery\":\"5\"} ]","payloadType":"json","x":400,"y":5220,"wires":[["ea8c8eae791a06dd","6d4a0b42074decfe","13625d0488d2850b"]]},{"id":"ea8c8eae791a06dd","type":"debug","z":"d1395164b4eec73e","name":"msg.payload[4].val","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload[4].val","targetType":"msg","statusVal":"payload[4].val","statusType":"auto","x":630,"y":5160,"wires":[]},{"id":"6d4a0b42074decfe","type":"debug","z":"d1395164b4eec73e","name":"msg.payload[5].val","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload[5].val","targetType":"msg","statusVal":"payload[4].val","statusType":"auto","x":630,"y":5220,"wires":[]},{"id":"13625d0488d2850b","type":"debug","z":"d1395164b4eec73e","name":"msg.payload[6].val","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload[6].val","targetType":"msg","statusVal":"payload[4].val","statusType":"auto","x":630,"y":5280,"wires":[]},{"id":"ad03663e3fc51aa7","type":"switch","z":"d1395164b4eec73e","name":"route on msg.payload.id","property":"payload.id","propertyType":"msg","rules":[{"t":"eq","v":"0x0B","vt":"num"},{"t":"eq","v":"0x0C","vt":"str"},{"t":"eq","v":"0x19","vt":"str"}],"checkall":"false","repair":false,"outputs":3,"x":570,"y":5400,"wires":[["fcbf5eb9b794a3fb"],["dc6a916b731cde9d"],["1b77de4539b79cb2"]]},{"id":"fcbf5eb9b794a3fb","type":"debug","z":"d1395164b4eec73e","name":"msg.payload.val","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload.val","targetType":"msg","statusVal":"payload","statusType":"auto","x":820,"y":5340,"wires":[]},{"id":"dc6a916b731cde9d","type":"debug","z":"d1395164b4eec73e","name":"msg.payload.val","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload.val","targetType":"msg","statusVal":"error_count","statusType":"auto","x":820,"y":5400,"wires":[]}]
