i need to extract the tho date from the json object. The date's always change depending what day it is.
The data in picture is from the last date's, 2022-01-03 and 2022-01-04.
Welcome to the forum @Stevom
For the record that is not a JSON object (JSON is a string representation of an object). That is a javascript object.
Given the data you show, exactly what to you want to get out of it?
i want to extract the two values from the two date's under watt_hours_day.
This is some data for today and tomorrow.
Do you know what dates you expect in the message? If so there is a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
If you don't know what dates there are then you can use javascript in a function. In particular look at Object.keys(). You can use something like
let keys = msg.payload.watt_hours_day
which will give you an array of the date strings.
Hi ,
Thanks for the help.
The two dates are always the date for today and tomorrow.
Here is an example using A change node, you could also do it using a function node, You do not say how you want the data presented.
[{"id":"d09c6bd0.6d9d9","type":"inject","z":"1378ba83.90c825","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"watt_hour_days\":{\"2021-01-04\":1234,\"2021-01-05\":5678}}","payloadType":"json","x":200,"y":340,"wires":[["b515b3a4.437d18"]]},{"id":"b515b3a4.437d18","type":"change","z":"1378ba83.90c825","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$keys($$.payload.watt_hour_days).{\"date\": $, \"value\" :$lookup($$.payload.watt_hour_days, $)}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":390,"y":340,"wires":[["ee01ad6c.ac18b"]]},{"id":"ee01ad6c.ac18b","type":"debug","z":"1378ba83.90c825","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":620,"y":340,"wires":[]}]
expression
"date": $,
"value" :$lookup($$.payload.watt_hour_days, $)
When you posted your question you failed to posted any usable data(image can not be copied). I therefore created my own for the example. If you look at the property names they are not the same. Edit the expression and add your property names.
eg. $$.payload.result.watt_hours_day
Thank you very much.
