Payload
{"applicationID":"1","applicationName":"cloud","data":[3,72,94,140,0,12,16,236,55,45,223,38,4,245,106,62],"devEUI":"20635f01d1000002","deviceName":"abeeway tracker","fCnt":588,"fPort":18,"rxInfo":[{"altitude":0,"latitude":0,"loRaSNR":9.8,"longitude":0,"mac":"24e124fffef0a78e","name":"24e124fffef0a78e","rssi":-59,"time":"2020-11-12T07:01:22.759152Z"}],"time":"2020-11-12T07:01:22.759152Z","txInfo":{"adr":true,"codeRate":"4/5","dataRate":{"bandwidth":125,"modulation":"LORA","spreadFactor":7},"frequency":865402500}}
[{"id":"506b83c1.56ee6c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"57373220.09238c","type":"mqtt in","z":"506b83c1.56ee6c","name":"","topic":"bachloo.rahul@gmail.com/test","qos":"0","datatype":"json","broker":"55bef158.86a7c","x":210,"y":80,"wires":[["8606fe2a.c2499"]]},{"id":"d5396d84.2231e","type":"debug","z":"506b83c1.56ee6c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":520,"y":140,"wires":[]},{"id":"8606fe2a.c2499","type":"base64","z":"506b83c1.56ee6c","name":"","action":"","property":"payload.data","x":343,"y":167,"wires":[["d5396d84.2231e","449795b6.55bf6c"]]},{"id":"449795b6.55bf6c","type":"buffer-parser","z":"506b83c1.56ee6c","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"item1","offset":0,"length":1,"offsetbit":0,"scale":1,"mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"setTopic":true,"x":420,"y":260,"wires":[[]]},{"id":"55bef158.86a7c","type":"mqtt-broker","name":"","broker":"maqiatto.com","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
How to use buffer parser node for parsing the data attribute?
very silly mistake
