Hello there!
Long time playing around node-red but I never had unknown issues so far, until today...
I was testing few things with node-sqlite in home assistant node-red add on, running on vmware virtual machine. Installed with no issues, running just fine.
Today I tried to migrate it all to a raspberry pi4 but I got an error while building sqlite3 and I have no idea where is main error from the log. Can anybody help me figuring that line out?
pi4 error log:
2021-12-07T12:40:37.048Z Install : node-red-node-sqlite 1.0.1
2021-12-07T12:40:37.209Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-node-sqlite@1.0.1
2021-12-07T12:40:50.661Z [err] npm
2021-12-07T12:40:50.662Z [err]
2021-12-07T12:40:50.662Z [err] WARN
2021-12-07T12:40:50.663Z [err] deprecated
2021-12-07T12:40:50.663Z [err] har-validator@5.1.5: this library is no longer supported
2021-12-07T12:40:50.887Z [err] npm
2021-12-07T12:40:50.887Z [err] WARN
2021-12-07T12:40:50.888Z [err]
2021-12-07T12:40:50.888Z [err] deprecated
2021-12-07T12:40:50.888Z [err] uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
2021-12-07T12:40:50.962Z [err] npm
2021-12-07T12:40:50.963Z [err]
2021-12-07T12:40:50.963Z [err] WARN
2021-12-07T12:40:50.964Z [err]
2021-12-07T12:40:50.964Z [err] deprecated
2021-12-07T12:40:50.964Z [err] request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
2021-12-07T12:40:51.011Z [err] npm
2021-12-07T12:40:51.012Z [err] WARN
2021-12-07T12:40:51.013Z [err]
2021-12-07T12:40:51.013Z [err] deprecated
2021-12-07T12:40:51.014Z [err] node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2021-12-07T12:40:51.226Z [err] npm
2021-12-07T12:40:51.227Z [err] WARN
2021-12-07T12:40:51.227Z [err] deprecated
2021-12-07T12:40:51.228Z [err] tar@2.2.2: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap.
2021-12-07T12:40:56.883Z [err] npm
2021-12-07T12:40:56.883Z [err] ERR! code 1
2021-12-07T12:40:56.883Z [err] npm ERR! path /config/node-red/node_modules/sqlite3
2021-12-07T12:40:56.889Z [err] npm ERR! command failed
2021-12-07T12:40:56.890Z [err] npm ERR! command sh -c node-pre-gyp install --fallback-to-build
2021-12-07T12:40:56.890Z [err] npm ERR! Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm --napi_version=8 --node_abi_napi=napi --napi_build_version=3 --node_napi_label=napi-v3' (1)
2021-12-07T12:40:56.890Z [err] npm ERR! node-pre-gyp info it worked if it ends with ok
2021-12-07T12:40:56.890Z [err] npm ERR! node-pre-gyp info using node-pre-gyp@0.11.0
2021-12-07T12:40:56.890Z [err] ERR! node-pre-gyp info using node@16.13.1 | linux | arm
2021-12-07T12:40:56.890Z [err] npm ERR! node-pre-gyp WARN Using request for node-pre-gyp https download
2021-12-07T12:40:56.890Z [err] npm ERR! node-pre-gyp info check checked for "/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm/node_sqlite3.node" (not found)
2021-12-07T12:40:56.891Z [err] npm ERR! node-pre-gyp http GET https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v5.0.2/napi-v3-linux-arm.tar.gz
2021-12-07T12:40:56.891Z [err] npm ERR! node-pre-gyp http 403 https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v5.0.2/napi-v3-linux-arm.tar.gz
2021-12-07T12:40:56.891Z [err] node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v5.0.2/napi-v3-linux-arm.tar.gz
2021-12-07T12:40:56.891Z [err] npm ERR! node-pre-gyp WARN Pre-built binaries not found for sqlite3@5.0.2 and node@16.13.1 (node-v93 ABI, musl) (falling back to source compile with node-gyp)
2021-12-07T12:40:56.891Z [err] npm ERR! node-pre-gyp http 403 status code downloading tarball https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v5.0.2/napi-v3-linux-arm.tar.gz
2021-12-07T12:40:56.892Z [err] npm ERR! gyp info it worked if it ends with ok
2021-12-07T12:40:56.892Z [err] npm ERR! gyp info using node-gyp@8.3.0
2021-12-07T12:40:56.892Z [err] npm ERR! gyp info using node@16.13.1 | linux | arm
2021-12-07T12:40:56.892Z [err] ERR! gyp info ok
2021-12-07T12:40:56.893Z [err] gyp info using node@16.13.1 | linux | arm
2021-12-07T12:40:56.893Z [err] npm ERR! gyp info find Python using Python version 3.9.7 found at "/usr/bin/python3"
2021-12-07T12:40:56.893Z [err] npm ERR! gyp info spawn /usr/bin/python3
2021-12-07T12:40:56.893Z [err] npm ERR! gyp info spawn args [
2021-12-07T12:40:56.893Z [err] gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2021-12-07T12:40:56.893Z [err] npm ERR! gyp info spawn args 'binding.gyp',
2021-12-07T12:40:56.893Z [err] npm ERR! gyp info spawn args '-f',
2021-12-07T12:40:56.893Z [err] npm ERR! gyp info spawn args 'make',
2021-12-07T12:40:56.894Z [err] gyp info spawn args '-I',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '/config/node-red/node_modules/sqlite3/build/config.gypi',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '-I',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '/root/.cache/node-gyp/16.13.1/include/node/common.gypi',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '-Dlibrary=shared_library',
2021-12-07T12:40:56.894Z [err] gyp info spawn args '-Dvisibility=default',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '-Dnode_root_dir=/root/.cache/node-gyp/16.13.1',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
2021-12-07T12:40:56.894Z [err] npm ERR! gyp info spawn args '-Dnode_lib_file=/root/.cache/node-gyp/16.13.1/<(target_arch)/node.lib',
2021-12-07T12:40:56.895Z [err] ERR! gyp info spawn args '-Dmodule_root_dir=/config/node-red/node_modules/sqlite3',
2021-12-07T12:40:56.895Z [err] npm ERR! gyp info spawn args '-Dnode_engine=v8',
2021-12-07T12:40:56.895Z [err] npm ERR! gyp info spawn args '--depth=.',
2021-12-07T12:40:56.895Z [err] ERR! gyp info spawn args '--no-parallel',
2021-12-07T12:40:56.895Z [err] ERR! gyp info spawn args '--generator-output',
2021-12-07T12:40:56.896Z [err] ERR! gyp info spawn args 'build',
2021-12-07T12:40:56.896Z [err] npm ERR! gyp info spawn args '-Goutput_dir=.'
2021-12-07T12:40:56.896Z [err] gyp info spawn args ]
2021-12-07T12:40:56.896Z [err] npm ERR! gyp info ok
2021-12-07T12:40:56.896Z [err] npm ERR! gyp info it worked if it ends with ok
2021-12-07T12:40:56.896Z [err] npm ERR! gyp info using node-gyp@8.3.0
2021-12-07T12:40:56.896Z [err] npm ERR! gyp info using node@16.13.1 | linux | arm
2021-12-07T12:40:56.897Z [err] ERR! gyp ERR! build error
2021-12-07T12:40:56.897Z [err] npm ERR! gyp ERR! stack Error: not found: make
2021-12-07T12:40:56.897Z [err] ERR! gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:10:17)
2021-12-07T12:40:56.897Z [err] npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:57:18
2021-12-07T12:40:56.897Z [err] npm ERR! gyp ERR! stack at new Promise (<anonymous>)
2021-12-07T12:40:56.897Z [err] npm ERR! gyp ERR! stack at step (/usr/lib/node_modules/npm/node_modules/which/which.js:54:21)
2021-12-07T12:40:56.897Z [err] npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:71:22
2021-12-07T12:40:56.898Z [err] ERR! gyp ERR! stack at new Promise (<anonymous>)
2021-12-07T12:40:56.898Z [err] npm ERR! gyp ERR! stack at subStep (/usr/lib/node_modules/npm/node_modules/which/which.js:69:33)
2021-12-07T12:40:56.898Z [err] ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:80:22
2021-12-07T12:40:56.898Z [err] npm ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
2021-12-07T12:40:56.898Z [err] ERR! gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
2021-12-07T12:40:56.898Z [err] npm ERR! gyp ERR! System Linux 5.10.17-v7l
2021-12-07T12:40:56.898Z [err] gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=3" "--node_napi_label=napi-v3"
2021-12-07T12:40:56.898Z [err] npm ERR! gyp ERR! cwd /config/node-red/node_modules/sqlite3
2021-12-07T12:40:56.899Z [err] gyp ERR! node -v v16.13.1
2021-12-07T12:40:56.899Z [err] npm ERR! gyp ERR! node-gyp -v v8.3.0
2021-12-07T12:40:56.899Z [err] gyp ERR! not ok
2021-12-07T12:40:56.899Z [err] npm ERR! node-pre-gyp ERR! build error
2021-12-07T12:40:56.899Z [err] node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm/node_sqlite3.node --module_name=node_sqlite3 --module_path=/config/node-red/node_modules/sqlite3/lib/binding/napi-v3-linux-arm --napi_version=8 --node_abi_napi=napi --napi_build_version=3 --node_napi_label=napi-v3' (1)
2021-12-07T12:40:56.899Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/config/node-red/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
2021-12-07T12:40:56.899Z [err] npm ERR! node-pre-gyp ERR! stack at ChildProcess.emit (node:events:390:28)
2021-12-07T12:40:56.899Z [err] npm ERR! node-pre-gyp ERR! stack at maybeClose (node:internal/child_process:1064:16)
2021-12-07T12:40:56.899Z [err] npm ERR! node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:301:5)
2021-12-07T12:40:56.900Z [err] ERR! node-pre-gyp ERR! System Linux 5.10.17-v7l
2021-12-07T12:40:56.900Z [err] npm ERR! node-pre-gyp ERR! command "/usr/bin/node" "/config/node-red/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
2021-12-07T12:40:56.900Z [err] ERR! node-pre-gyp ERR! cwd /config/node-red/node_modules/sqlite3
2021-12-07T12:40:56.900Z [err] npm ERR! node-pre-gyp ERR! node -v v16.13.1
2021-12-07T12:40:56.900Z [err] ERR! node-pre-gyp ERR! node-pre-gyp -v v0.11.0
2021-12-07T12:40:56.900Z [err] npm ERR! node-pre-gyp ERR! not ok
2021-12-07T12:40:56.964Z [err]
2021-12-07T12:40:56.965Z [err] npm ERR! A complete log of this run can be found in:
2021-12-07T12:40:56.965Z [err] npm ERR! /root/.npm/_logs/2021-12-07T12_40_56_906Z-debug.log
2021-12-07T12:40:56.999Z rc=1
pi4 node-red env info
Add-on version: 10.2.0
You are running the latest version of this add-on.
System: Home Assistant OS 6.6 (armv7 / raspberrypi4)
Home Assistant Core: 2021.10.7
Home Assistant Supervisor: 2021.10.8
7 Dec 17:34:40 - [info] Node-RED version: v2.1.4
7 Dec 17:34:40 - [info] Node.js version: v16.13.1
7 Dec 17:34:40 - [info] Linux 5.10.17-v7l arm LE
7 Dec 17:34:41 - [info] Loading palette nodes
7 Dec 17:34:47 - [info] Dashboard version 3.1.2 started at /endpoint/ui
7 Dec 17:34:47 - [warn] ------------------------------------------------------
7 Dec 17:34:47 - [warn] [node-red-node-rbe/rbe] 'rbe' already registered by module node-red
7 Dec 17:34:47 - [info] Settings file : /etc/node-red/config.js
7 Dec 17:34:47 - [info] Context store : 'default' [module=memory]
7 Dec 17:34:47 - [info] User directory : /config/node-red/
7 Dec 17:34:47 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Dec 17:34:47 - [info] Flows file : /config/node-red/flows.json
7 Dec 17:34:48 - [info] Server now running at http://127.0.0.1:46836/
node-red env info on working vm ware
System: Home Assistant OS 6.6 (amd64 / qemux86-64)
Home Assistant Core: 2021.11.5
7 Dec 18:11:52 - [info] Node-RED version: v2.1.4
7 Dec 18:11:52 - [info] Node.js version: v16.13.1
7 Dec 18:11:52 - [info] Linux 5.10.75 x64 LE
7 Dec 18:11:53 - [info] Loading palette nodes
7 Dec 18:11:58 - [info] Dashboard version 3.1.2 started at /endpoint/ui
7 Dec 18:12:00 - [info] Settings file : /etc/node-red/config.js
7 Dec 18:12:00 - [info] Context store : 'default' [module=memory]
7 Dec 18:12:00 - [info] User directory : /config/node-red/
7 Dec 18:12:00 - [info] Flows file : /config/node-red/flows.json
7 Dec 18:12:00 - [info] Server now running at http://127.0.0.1:46836/
