Fail to install tensorflow on raspberry pi Node-red
2022-11-29T06:27:34.900Z Install : node-red-contrib-tensorflow 0.3.1
2022-11-29T06:27:32.514Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tensorflow@0.3.1
2022-11-29T06:27:34.801Z [err] npm
2022-11-29T06:27:34.805Z [err]
2022-11-29T06:27:34.806Z [err] WARN
2022-11-29T06:27:34.807Z [err]
2022-11-29T06:27:34.807Z [err] config
2022-11-29T06:27:34.808Z [err] production Use --omit=dev instead.
2022-11-29T06:28:12.849Z [err] npm
2022-11-29T06:28:12.851Z [err]
2022-11-29T06:28:12.853Z [err] ERR! code
2022-11-29T06:28:12.854Z [err] ENOTEMPTY
2022-11-29T06:28:12.855Z [err] npm ERR!
2022-11-29T06:28:12.856Z [err] syscall rename
2022-11-29T06:28:12.857Z [err] npm ERR! path /home/pi/.node-red/node_modules/adm-zip
2022-11-29T06:28:12.858Z [err] npm ERR! dest /home/pi/.node-red/node_modules/.adm-zip-IJup2u0l
2022-11-29T06:28:12.859Z [err] npm ERR!
2022-11-29T06:28:12.860Z [err] errno -39
2022-11-29T06:28:12.866Z [err] npm ERR!
2022-11-29T06:28:12.867Z [err] ENOTEMPTY: directory not empty, rename '/home/pi/.node-red/node_modules/adm-zip' -> '/home/pi/.node-red/node_modules/.adm-zip-IJup2u0l'
2022-11-29T06:28:12.877Z [err]
2022-11-29T06:28:12.878Z [err] npm ERR!
2022-11-29T06:28:12.879Z [err] A complete log of this run can be found in:
2022-11-29T06:28:12.879Z [err] npm ERR! /home/pi/.npm/_logs/2022-11-29T06_27_34_607Z-debug-0.log
2022-11-29T06:28:12.936Z rc=217
this from the log
Anyone to help
This is an npm problem that appears occasionally, no-one is sure why. Look in the node_modules folder in the error and delete any folders that start with a dot. Then try again.
