HI,
To secure my node red flow, I have incorporated SSL certificates in my node red settings. When i am using a self signed SSL certificate, node red is starting fine, but when i am using the SSL certificate created by my organization my node red is showing error failed to get https settings. I have uploaded the error codes in my most.
Looking forward for solution.
Please post logs as text - so that they are more readable and searchable.
Dont forget to hit the </> code button before pasting (to ensure log text formatting is preserved in the post)
PS: this is a nodejs thing and there are lots of posts on the internet
Some common causes are
- getting the files mixed up (i.e. key and cert swapped)
- not including the
-----BEGIN PUBLIC KEY-----at the beginning and-----END PUBLIC KEY-----at the end.
Microsoft Windows [Version 10.0.20348.1487]
(c) Microsoft Corporation. All rights reserved.
C:\Users\sks398596>node-red
Failed to get https settings: Error: error:0480006C:PEM routines::no start line
at node:internal/tls/secure-context:69:13
at Array.forEach (<anonymous>)
at setCerts (node:internal/tls/secure-context:67:3)
at configSecureContext (node:internal/tls/secure-context:156:5)
at Object.createSecureContext (node:_tls_common:117:3)
at Server.setSecureContext (node:_tls_wrap:1354:27)
at Server (node:_tls_wrap:1218:8)
at new Server (node:https:74:3)
at Object.createServer (node:https:112:10)
at C:\Users\sks398596\AppData\Roaming\npm\node_modules\node-red\red.js:228:24
My Https setting is as follows in setting.js
/** The following property can be used to enable HTTPS
* This property can be either an object, containing both a (private) key
* and a (public) certificate, or a function that returns such an object.
* See http://nodejs.org/api/https.html#https_https_createserver_options_requestlistener
* for details of its contents.
/** Option 1: static object */
https: {
key: require("fs").readFileSync('C:/Users/sks398596/.node-red/certs/nred-key.crt'),
cert: require("fs").readFileSync('C:/Users/sks398596/.node-red/certs/nred-cert.crt')
/** Option 2: function that returns the HTTP configuration object */
// https: function() {
// // This function should return the options object, or a Promise
// // that resolves to the options object
// return {
// key: require("fs").readFileSync('privkey.pem'),
// cert: require("fs").readFileSync('cert.pem')
/** If the `https` setting is a function, the following setting can be used
* to set how often, in hours, the function will be called. That can be used
* to refresh any certificates.
//httpsRefreshInterval : 12,
/** The following property can be used to cause insecure HTTP connections to
* be redirected to HTTPS.
//requireHttps: true,
And?
Did you look inside the privkey.pem and cert.pem to check they had the correct content
Who ever gave them to might have mixed them up or removed the -----BEGIN and -----END lines!
Hi steve-Mcl,
I am using the option 1 key:nred-key.crt and certificate: nred-cert.crt. I have used openssl method to generate the key and CSR. Based on CSR file generated my IT support team has given the SSL certificate.
Hi, steve,
I converted my SSL certificate from .crt to .pem and opened in notepad. ---Begin and ----Start line are available in the certificate.
