Hi.
After a change from dhcp to static ip and node red port from 1880 to 5003 on raspbian.
I got this error. See Picture
Do i need to chnge something else to get this to work?
/Niclas
What version of node.js are you using? (node -v)
How did you install node-red?
installed it with this script bash <(curl -sL https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered)
v10.16.3
Is it possible that it is the browser i am using? Explorer from windows 2012
When you restart Node-RED can you copy all the messages to here? (moved to #general as not about creating nodes)
