So i just cloned master branch from github, and did npm install and npm test. I assumed they would pass, but they don't, and I can't figure out why. I don't have much experience with nodejs, hence looking for help.
~/node-red$ git status
On branch master
Your branch is up to date with 'origin/master'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
test/unit/@node-red/runtime/lib/nodes/.testUserHome/
nothing added to commit but untracked files present (use "git add" to track)
admin@ip-20-1-12-216:~/node-red$ git pull
Already up to date.
The tests always fail at HTTP Request Node while starting/creating SSL server instance.
ssl port 10335
Fatal error: Cannot init without a stop
=============================== Coverage summary ===============================
Statements : 40.75% ( 6829/16759 )
Branches : 33.14% ( 3433/10359 )
Functions : 42.38% ( 1056/2492 )
Lines : 41.52% ( 6737/16224 )
Warning: Task "nyc:all" failed. Use --force to continue.
Aborted due to warnings.
I also see several warnings like this -
7 Mar 20:15:32 - [warn] Deprecated API warning: Calls to RED.util.evaluateJSONataExpression must include a callback. This will not be optional in Node-RED 4.0. Please identify the node from the following stack and check for an update on npm. If none is available, please notify the node author.
7 Mar 20:15:32 - [warn] Error
at Object.evaluateJSONataExpression (/home/admin/node-red/packages/node_modules/@node-red/util/lib/util.js:194:1272)
at Context.<anonymous> (/home/admin/node-red/test/unit/@node-red/util/lib/util_spec.js:647:33)
at callFn (/home/admin/node-red/node_modules/mocha/lib/runnable.js:366:21)
at Runnable.run (/home/admin/node-red/node_modules/mocha/lib/runnable.js:354:5)
at Runner.runTest (/home/admin/node-red/node_modules/mocha/lib/runner.js:678:10)
at /home/admin/node-red/node_modules/mocha/lib/runner.js:801:12
at next (/home/admin/node-red/node_modules/mocha/lib/runner.js:593:14)
at /home/admin/node-red/node_modules/mocha/lib/runner.js:603:7
at next (/home/admin/node-red/node_modules/mocha/lib/runner.js:486:14)
at Immediate._onImmediate (/home/admin/node-red/node_modules/mocha/lib/runner.js:571:5
I am not sure if they are related to the fatal error above.
Any help is appreciated. Thanks.
