I try to create a node with 7 condition if all condition it activate my blower, if it not it turn off...
The blower take hot air in my basement fire place(sensor1), and transfer it in my living-room(sensor2)
My others condition are slider in my lovelace who let my choose the temp Min(3) end Max(4) of my basement, and the temp we will reach in te living-room (5). I have also had a adjustable tolerance (6) to limit the trigger, and a Automation on/off(7).
My Input are group in a Joint node and output are set up, but I have trouble to figure how to set up function...
What I try to do is
IF switch (7) is ON
AND my temp (sensor1) is between the preset temp (3) and (4) (+/- tolerance (6))
AND my temp (sensor2) is lower then the preset temp (5) (+/- tolerance (6))
Then start my blower
Hard to say for sure as i dont know your variable names and msg structure, You need to add a output from a debug, after the node that creates your msg.
The structure of such a if statement would be something like below.
if (switch7 === "ON" &&
mytempsensor1 > (temp3 - tolerance) &&
mytempsensor1 < (temp4 + tolerance) &&
mytempsensor2 < (temp5 - tolerance) ) {
// do somthing when true
msg.payload = true;
}else{
// do something when false
msg.payload = false;
if ("input_boolean.souffleur_automatique" === "1" &&
"multi_sensor1/sensor/temperature_coin_a_bois/state" > ("input_number.temperature_poele_min" - "input_number.temperature_tolerence") &&
"multi_sensor1/sensor/temperature_coin_a_bois/state" < ("input_number.temperature_poele" + "input_number.temperature_tolerence") &&
"cam3/sensor/garage_temperature/state" < ("input_number.temperature_salon" - "input_number.temperature_tolerence") ) {
msg.payload = true;
return (msg, null );
}else{
return (null, msg );
Correct will be return [null, msg]
I can not help with images. If you want more help create a test flow, consisting of an inject with object set in msg.payload , a function node with your code and a debug node. Then we will have the info to help.
Sorry, I am a new user of node red maybe 6-7 days, what is a test flow?
A shorter version of your flow with less junk.
an inject containing the debug output from after the join node. In the debug window to the right of the object name , when you hoover mouse you get options , one is to copy value. you can then paste that value in the inject node and select json.
a copy of your function node.
and a debug/s nodes to show values.
select the nodes by holding Ctrl and selecting them with the mouse. Then press Ctrl/e and copy text.
Then paste text here by pressing </> aat top of reply window, and pasting the code between the backticks, like below.
code
Looking here the values are in msg.payload.
so add msg.payload to the front of all your variables.
Input
input_number.temperature_tolerence : msg.payload : Object
object
multi_sensor1/sensor/temperature_coin_a_bois/state: 46
cam3/sensor/garage_temperature/state: 26
input_number.souffleur_automatique: 1
input_number.temperature_poele: 65
input_number.temperature_poele_min: 24.5
input_number.temperature_salon: 25
input_number.temperature_tolerence: 1
function
msg.payload = true;
return (msg, null);
}else{
return (null, msg);
I still do not have a copy of the object, that i can just copy and paste. If you copy value correctly using copy value icon to right of msg.payload, then i can work with it, but what you have pasted is not a valid json.
[{"id":"c66fb972.1c42f8","type":"server-state-changed","z":"756107df.057b38","name":"Switch Automation","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.souffleur_automatique","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":true,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":90,"y":400,"wires":[["6fc0025a.1ef98c"]]},{"id":"b5554eb2.fbcce","type":"server-state-changed","z":"756107df.057b38","name":"Temp_max poèle","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperature_poele","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":80,"y":40,"wires":[["6fc0025a.1ef98c"]]},{"id":"eec2f33c.01b7a","type":"server-state-changed","z":"756107df.057b38","name":"Temp_min poèle","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperature_poele_min","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":80,"y":100,"wires":[["6fc0025a.1ef98c"]]},{"id":"b122bc0a.d2af6","type":"server-state-changed","z":"756107df.057b38","name":"Temp_salon","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperature_salon","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":70,"y":280,"wires":[["6fc0025a.1ef98c"]]},{"id":"c9bb1e44.a69c2","type":"server-state-changed","z":"756107df.057b38","name":"tolérence temp","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_number.temperature_tolerence","entityidfiltertype":"exact","outputinitially":true,"state_type":"num","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":80,"y":220,"wires":[["6fc0025a.1ef98c"]]},{"id":"c9f5b654.4a0198","type":"mqtt in","z":"756107df.057b38","name":"Temp","topic":"multi_sensor1/sensor/temperature_coin_a_bois/state","qos":"0","datatype":"json","broker":"f31ab881.110a68","x":50,"y":160,"wires":[["6fc0025a.1ef98c"]]},{"id":"eaeb8177.228ef","type":"mqtt in","z":"756107df.057b38","name":"Temp","topic":"cam3/sensor/garage_temperature/state","qos":"0","datatype":"json","broker":"f31ab881.110a68","x":50,"y":340,"wires":[["6fc0025a.1ef98c"]]},{"id":"f31ab881.110a68","type":"mqtt-broker","z":"","name":"","broker":"192.168.1.26","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Ok and what is wrong?
This is not a test flow and does not contain any functon or inject node
This is an example of a correctly formated json notice the { } and the " " and the :
{"topic":"Mypi/2/KW","payload":{"KW_Total":434},"qos":0,"retain":false,"_msgid":"ef0287b6.34ca08"}
if you look at image you can see my cursor over the copy value icon.
{"multi_sensor1/sensor/temperature_coin_a_bois/state":42.4,"cam3/sensor/garage_temperature/state":25.8,"input_number.souffleur_automatique":1,"input_number.temperature_poele":65,"input_number.temperature_poele_min":24.5,"input_number.temperature_salon":25,"input_number.temperature_tolerence":1}
Here is a test flow
[{"id":"b95ccd5.63ef1b","type":"inject","z":"8d22ae29.7df6d","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"multi_sensor1/sensor/temperature_coin_a_bois/state\":42.4,\"cam3/sensor/garage_temperature/state\":25.8,\"input_number.souffleur_automatique\":1,\"input_number.temperature_poele\":65,\"input_number.temperature_poele_min\":24.5,\"input_number.temperature_salon\":25,\"input_number.temperature_tolerence\":1}","payloadType":"json","x":140,"y":1940,"wires":[["31a96c2c.4f8c9c"]]},{"id":"31a96c2c.4f8c9c","type":"function","z":"8d22ae29.7df6d","name":"","func":"if (msg.payload[\"input_number.souffleur_automatique\"] === 1 && \n msg.payload[\"multi_sensor1/sensor/temperature_coin_a_bois/state\"] > (msg.payload[\"input_number.temperature_poele_min\"] - msg.payload[\"input_number.temperature_tolerence\"]) &&\n msg.payload[\"multi_sensor1/sensor/temperature_coin_a_bois/state\"] < (msg.payload[\"input_number.temperature_poele\"] + msg.payload[\"input_number.temperature_tolerence\"]) &&\n msg.payload[\"cam3/sensor/garage_temperature/state\"] < (msg.payload[\"input_number.temperature_salon\"] - msg.payload[\"input_number.temperature_tolerence\"]) ) {\n // do somthing when true\n msg.payload = true;\nreturn [msg, null];\n}else{\n // do something when false\n msg.payload = false;\n return [null, msg];\n\n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","x":330,"y":1960,"wires":[["be48273.628c958"],["be48273.628c958"]]},{"id":"be48273.628c958","type":"debug","z":"8d22ae29.7df6d","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":560,"y":1940,"wires":[]},{"id":"5f8cb3d4.47db5c","type":"inject","z":"8d22ae29.7df6d","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"multi_sensor1/sensor/temperature_coin_a_bois/state\":42.4,\"cam3/sensor/garage_temperature/state\":23.8,\"input_number.souffleur_automatique\":1,\"input_number.temperature_poele\":65,\"input_number.temperature_poele_min\":24.5,\"input_number.temperature_salon\":25,\"input_number.temperature_tolerence\":1}","payloadType":"json","x":130,"y":2000,"wires":[["31a96c2c.4f8c9c"]]}]
you will see i put the json in the inject node for testing
if you create a json that should return true in a seperate inject node you can the test the function.
edit/ changed === "1" to === 1
Before that change, always false at te bottom output
After remove " " I have nothing at the output...
I saw your input are set to string, mine are set to number, it is made a difference?
