Feature Request Folder Hierarchical Flow Organization / Folder Structure
Feature Request: Hierarchical Flow Organization / Folder Structure
Summary
Add support for organizing flows in a hierarchical folder structure, similar to what Blockly offers, to improve navigation and management of complex Node-RED projects.
Current Problem
In larger Node-RED installations with multiple automation areas (e.g., coffee machine monitoring, aquarium control, security systems, garden automation), the current flat tab structure becomes unmanageable:
  • All flows appear as a single row of tabs
  • No way to group related flows together
  • Difficult to navigate when you have 10+ flows
  • No visual hierarchy or organization possible
  • Groups within flows become cluttered and hard to overview
Proposed Solution
Implement a folder-based organization system in the flow tabs area, similar to Blockly's category structure:
๐Ÿ“ ๐Ÿ  Smart Home
  โ”œโ”€โ”€ ๐Ÿ“ โ˜• Kitchen
  โ”‚   โ”œโ”€โ”€ Coffee Machine Control
  โ”‚   โ”œโ”€โ”€ Coffee Monitoring
  โ”‚   โ””โ”€โ”€ Coffee Statistics
  โ”œโ”€โ”€ ๐Ÿ“ ๐Ÿ  Aquarium
  โ”‚   โ”œโ”€โ”€ Temperature Control
  โ”‚   โ”œโ”€โ”€ Lighting System
  โ”‚   โ”œโ”€โ”€ Filter Control
  โ”‚   โ””โ”€โ”€ Water Quality Monitoring
  โ””โ”€โ”€ ๐Ÿ“ ๐Ÿšช Security
      โ”œโ”€โ”€ Door Sensors
      โ””โ”€โ”€ Alarm System
Expected Benefits
  1. Better Organization: Logical grouping of related flows
  2. Improved Navigation: Collapsible folders reduce visual clutter
  3. Scalability: Easily manage 20+ flows without losing overview
  4. User Experience: Similar to file explorers users are familiar with
  5. Project Structure: Better organization for team environments
Use Case Example
I'm managing a home automation system with:
  • Coffee machine flow (monitoring, statistics, alerts)
  • Aquarium system (temperature, lighting, filtering, feeding)
  • Security flows (doors, cameras, alarms)
  • Garden automation (irrigation, sensors)
Currently, I have 12+ tabs in a single row, making it hard to quickly find the right flow for maintenance or debugging.
Similar Implementations
  • Blockly: Excellent folder-based organization for code blocks
  • Home Assistant: Dashboard organization with folders
  • Grafana: Dashboard folders for better organization
  • VS Code: File explorer with collapsible folders
Proposed Implementation Ideas
  1. Right-click context menu on tabs: "Create Folder", "Move to Folder"
  2. Drag & Drop flows between folders
  3. Collapsible folder tree in sidebar or above current tab area
  4. Folder-level operations: Export/Import entire folder
  5. Breadcrumb navigation when inside folders
Alternative Solutions Considered
  • Naming conventions (e.g., "AQ-Temperature", "AQ-Lighting") - but this only provides visual grouping
  • Multiple Node-RED instances - adds complexity and resource overhead
  • Current Groups feature - becomes cluttered with many flows
Impact
This feature would significantly improve the user experience for anyone managing complex Node-RED installations, making it more suitable for larger home automation projects and professional environments.
This request comes from practical daily use of Node-RED for home automation with multiple subsystems. The current flat structure becomes a real bottleneck when managing 10+ flows.
since 2018 to 2023
I previously managed 170+ automations in Blockly (120 for marine aquarium control) - this was only possible due to the folder structure. Without it, I would have been completely lost.
I also manage my flows by "flow tabs", i.e., larger systems are a combination of reusable flows, each being a single tab. For example, I have a flow that does install, publish, push for my packages developed in Node-RED for Node-RED. For example the FlowHub node package is developed as a flow which in turn uses the install, publish, push flow to install the package locally, to push it to GitHub and to publish it to NPM.
To manage this setup I use the flowhub package integrated into Node-RED. The FlowHub sidebar contains a list of flows:
Top half are the flows hosted in my github repository (is private), bottom shows a check for whether I have already imported the flow into NR.
For organisation, I have convention of naming my flow using "[topic] name" where the topic (as shown in the screenshot) becomes a category. The folder structure only has a depth of one, i.e. there aren't sub-sub-folders.
An example of the folder structure that FlowHub creates in GitHub, check the flow test suite repository. That repository is the location to which flows are posted when I do a push inside NR from my FlowHub sidebar.
Documentation of flows is done using the tab documentation, that is then shown on the corresponding web page:
In that way, documentation of flows lives with the flows and everything is self-contained.
That is my solution to the problem of flow management.
Yes thats nice idea but not the same as blockly folder management
why subflows why not in subflow create folders to put flows inside i know must be down compatible to other versions but is ist so hard to coding some feature.
node-red is very structured and clear but very poor when it comes to managing or storing flows
