Feature request - node Text background color
Is possible to implement this setting in the node Text?
Yes, I know how to do at present, but it would be much easier to have this specific property ....
I'm not sure what you are referring to; as others might feel similar, that's most probably the reason why you didn't get any reply for about half a day. Usually this forum is quite responsive...
So, what is the feature you're proposing? To change the color of any given node from the editor... ? :thinking:
Could you please provide an example of what you expect to get - and perhaps a bit of reasoning, why this should be implemented?
