Hi all,
on each call of http://:1880/test the old text should be shown up onto the page utilising onload function in combination with {{payload}} as the following flow outlines as example:
[{"id":"196c09a7.6b48d6","type":"http response","z":"b83beaae.9b4368","name":"","statusCode":"","headers":{},"x":509,"y":101,"wires":[]},{"id":"6858a3dc.35d3ac","type":"http in","z":"b83beaae.9b4368","name":"","url":"/test","method":"get","upload":false,"swaggerDoc":"","x":147,"y":134,"wires":[["d91fc6d1.fbe778"]]},{"id":"d91fc6d1.fbe778","type":"template","z":"b83beaae.9b4368","name":"Config!","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":" \n \n <script type="text/javascript">\n function test() {\n var tst = "This works!"; \n // document.getElementById("oldText").innerHTML = tst; \n document.getElementById("oldText").innerHTML = {{payload}}; \n }\n \n\n<body onload="test()" >\n\n \n\n <form action="/test" method="post">\n \n
Old Text:
\n <label for="text">Change Text to: \n <input type="text" name="text" >\n <input type="submit"value="Send" >\n \n \n\n \n \n","output":"str","x":354,"y":101,"wires":[["196c09a7.6b48d6"]]},{"id":"19942353.277d8d","type":"http in","z":"b83beaae.9b4368","name":"","url":"/test","method":"post","upload":false,"swaggerDoc":"","x":141,"y":58,"wires":[["d91fc6d1.fbe778"]]},{"id":"8102c755.de83a8","type":"inject","z":"b83beaae.9b4368","name":"Trigger","topic":"","payload":"Does it work?","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":198,"y":197,"wires":[["d91fc6d1.fbe778"]]}]
Unfortunately, feeding payload into the flow does not show up as expected, while the static approach (via var tst = "This works!") works...
Can anyone give me some advice on how to resolve that issue? Maybe this approach is generally not ok...
Many thanks for your comments in advance!
Kind regards,
Michael
