I am guessing that you are then using the ui-template to display the table as you give no indication. This would work if you outputted the template to msg.template. Or you could do it all in the ui-template and angular ng-repeat.
Here is an example of both
[{"id":"21087e9d.fa4dca","type":"inject","z":"c791cbc0.84f648","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"stat\":{\"size\":23,\"created\":23,\"changed\":27},\"name\":\"tom\",\"fname\":\"tom\"}]","payloadType":"json","x":150,"y":680,"wires":[["358562c3.50dcce","7253e457.537274"]]},{"id":"358562c3.50dcce","type":"template","z":"c791cbc0.84f648","name":"","field":"template","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<style>\na:link {\n color: red;\n}\n\n/* visited link */\na:visited {\n color: green;\n}\n\n/* mouse over link */\na:hover {\n color: hotpink;\n}\n\n/* selected link */\na:active {\n color: \n</style>\n<table width=\"100%\">\n <tr><th>File Name</th><th>Size</th><th>Created</th><th>Changed</th></tr>\n {{#payload}}\n <tr>\n <td><a href=\"/download?filename={{name}}\" target=\"blank\">{{fname}}</a></td>\n <td>{{stat.size}}</td>\n <td>{{stat.created}}</td>\n <td>{{stat.changed}}</td>\n </tr>\n {{/payload}}\n</table>","output":"str","x":360,"y":680,"wires":[["a7450355.49e15"]]},{"id":"7253e457.537274","type":"ui_template","z":"c791cbc0.84f648","group":"8b5cde76.edd58","name":"","order":9,"width":0,"height":0,"format":"<style>\na:link {\n color: red;\n}\n\n/* visited link */\na:visited {\n color: green;\n}\n\n/* mouse over link */\na:hover {\n color: hotpink;\n}\n\n/* selected link */\na:active {\n color: \n</style>\n<table width=\"100%\">\n <tr><th>File Name</th><th>Size</th><th>Created</th><th>Changed</th></tr>\n <tr ng-repeat=\"rows in msg.payload\">\n <td><a href=\"/download?filename={{rows.name}}\" target=\"blank\">{{rows.fname}}</a></td>\n <td>{{rows.stat.size}}</td>\n <td>{{rows.stat.created}}</td>\n <td>{{rows.stat.changed}}</td>\n </tr>\n</table>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":330,"y":740,"wires":[[]]},{"id":"a7450355.49e15","type":"ui_template","z":"c791cbc0.84f648","group":"8b5cde76.edd58","name":"","order":9,"width":0,"height":0,"format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":540,"y":680,"wires":[[]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
standard mustache templete outputted to msg.template
<style>
a:link {
color: red;
/* visited link */
a:visited {
color: green;
a:hover {
color: hotpink;
/* selected link */
a:active {
color:
</style>
<table width="100%">
{{#payload}}
<tr>
<td><a href="/download?filename={{name}}" target="blank">{{fname}}</a></td>
</tr>
{{/payload}}
</table>
ui-template using ng-repeat
<style>
a:link {
color: red;
/* visited link */
a:visited {
color: green;
a:hover {
color: hotpink;
/* selected link */
a:active {
color:
</style>
<tr ng-repeat="rows in msg.payload">
<td><a href="/download?filename={{rows.name}}" target="blank">{{rows.fname}}</a></td>
</tr>
</table>
