ej3359
24 November 2020 19:58
1
i would like extract an element in a json base on the externalDeviceId attribut
my code:
var element = jsonState.deviceState.filter(el => el.externalDeviceId.includes("b827ebe81d30.3"));
jsonState is my json object.
the variable elemet receive the total array (devices) but not the unique element that externalDeviceId contain "b827ebe81d30.3"
my json:
may you help me?
Based on your image, shouldnt that be...
var element = jsonState.devices.filter(el => (el.externalDeviceId == "b827ebe81d30.3"));
Note also the array property name is devices not deviceState
(I am guessing some things as you haven't provided the data or any more context)
ej3359
25 November 2020 05:14
3
My project is a device cloud connector for Smartthings.
the json information from Samsung (the property name est "deviceState":
"headers": {
"schema": "st-schema",
"version": "1.0",
"interactionType": "stateRefreshResponse",
"requestId": "abc-123-456"
"deviceState": [
"externalDeviceId": "pdevice-1",
"deviceCookie": {},
"states": [
"component": "main",
"capability": "st.switch",
"attribute": "switch",
"value": "on"
"capability": "st.switchLevel",
"attribute": "level",
"value": 80
"capability": "st.healthCheck",
"attribute": "healthStatus",
"value": "online"
"capability": "st.colorControl",
"attribute": "hue",
"value": 0
"attribute": "saturation",
"value": 0
"capability": "st.colorTemperature",
"attribute": "colorTemperature",
"value": 3500
the documentation:
https://smartthings.developer.samsung.com/docs/devices/smartthings-schema/smartthings-schema-reference.html
I need to find an element in the deviceState array based on the externalDeviceId
I have tried:
var element = jsonState.deviceState.filter(el =>( el.externalDeviceId.includes("b827ebe81d30.3")));
i have the same problem, it return the array and not the element
That's what filter function does.
The filter() method creates a new array with all elements that pass the test implemented by the provided function.
If you are expecting 1 item, use find
ej3359
25 November 2020 08:13
5
Thank's !
And is it possible to use jsonata in a node function, like this:
var element = jsonState.deviceState[externalDeviceId="b827ebe81d30.3"]
No, you cannot use JSONata in the Function node.
ej3359
25 November 2020 16:57
7
And if i want delete this element?
There are quite a few ways.
I would possibly use filter method where the item is NOT equal.
Here is some ideas
janvda
26 November 2020 07:27
10
Most likely you can also achieve this using a JSONata expression in a change node.
