Is it possible, that I see the flow context data of an individual instances of a subflow somewhere (as I can see the flow values of a normal flow in the Context data menu flow section )?
If you have a flow context variable called foo then the nodes in a subflow can use $parent.foo to access it.
@sdalee No, the context sidebar doesn't currently show subflow context. There's an issue on the backlog to address this.
Thank you for your answer.
Too bad we can't see it now. I hope the developers will solve it soon.
