Flow context doesnt work
Hey,
when I use in the function-Node the following:
flow.xyz = "test";
and then try to get the value with the following in another function-Node:
let a = flow.xyz;
then my variable "a" is undefined?
But when I do the same with "context.flow.xyz" instead of just "flow.xyz" it works?
I thought and read in the docs that "context.flow" and just "flow" is the same?
Would appreciate any help and explanation!
Use the built in functions as described in the docs: Writing Functions : Node-RED
Note, newer Node-RED has built-in "autocomplete" and macros too
chrome_YxactETQuJ
