Flow.get syntax
hello,
can someone help me with the flow.get syntax.
var shd = flow.get('schedule_G2','groupID.G2.shd_12.ontopic');
msg.payload=shd;
I only want to read this one value and I am desperate because I always get everything and not dedicated ontopic from shed_12.
THX
I think this should do it:
var shd = flow.get('schedule_G2.shd_12.ontopic')
NOT SEE THE FOREST FOR THE TREES
THX
or
var shd = flow.get('schedule_G2').shd_12.ontopic;
msg.payload=shd;
Which is faster, but unless using large objects will be unnoticable.
hello
in order to optimise my code a little more and consolidate individual functions, I am wondering whether it is possible to include 12 as a variable in var shd = flow.get('schedule_G2.shd_12.ontopic')
I have been trying with trial and error to figure out how to include the variable so that the flow get call still works.
Is it possible that I can't do it directly in the call?
THX
in a function...
var num = 12; // or 13 or msg.number or whatever!
var path = `schedule_G2.shd_${num}.ontopic`;
msg.payload = flow.get(path);
learned something new again.
THX
As a beginner, may I ask one more question
I have seen that it does not work with ' ' but only with *
What are these called so I can search for them to understand the difference.
I have not worked with them before
  • i can't even use these characters in the forum
just escape them on forum
to show `
use \`
AHH OK. I am using a qwertz German keyboard
:wink: \ `
Template_literals
Thank you - i have two more questions:
  1. work this syntax for global.get too?
  2. can we use this syntax for the SET command too?
BR
Hubertus
Yes, same syntax works for all types of context and both get/set
Perfect! Thank you.
Once more: is the context protected against competing write access?
