Flow Set $parent.<Dynamic Name>
I'm storing the flow context in the parent for a subflow.
I need to name the variable dynamically based on a login name.
let userName = env.get("USERNAME");
if (msg.hasOwnProperty('UserName')) userName = msg.UserName;
let wSession = {};
wSession.session = "JSESSIONID=" + msg.payload.result.sessionID;
msg.wSession = wSession.session
flow.set("$parent.userName", wSession );
This does not work of course, the flow is stored against the property userName and not the value of userName.
Harry
Something like
flow.set(`$parent.${userName}`, wSession )
You could rewrite the first lines as
const userName = msg.UserName ?? env.get("USERNAME")
and, personally I would also use
wSession.session = `JSESSIONID=${msg.payload.result.sessionID}`
Note that you don't generally need semi-colons.
