FlowFuse 502 Bad Gateway
I'm trying to run flowfuse local on docker.
following the instruction: Docker install • FlowFuse Docs
Only i get a error in the "flowforge-forge-1" container.
node:internal/modules/cjs/loader:1143
  throw err;
Error: Cannot find module './config'
Require stack:
- /usr/src/forge/app/node_modules/@flowfuse/flowfuse/forge/forge.js
- /usr/src/forge/app/node_modules/@flowfuse/flowfuse/forge/app.js
    at Module._resolveFilename (node:internal/modules/cjs/loader:1140:15)
    at Module._load (node:internal/modules/cjs/loader:981:27)
    at Module.require (node:internal/modules/cjs/loader:1231:19)
    at require (node:internal/modules/helpers:177:18)
    at Object.<anonymous> (/usr/src/forge/app/node_modules/@flowfuse/flowfuse/forge/forge.js:11:16)
    at Module._compile (node:internal/modules/cjs/loader:1364:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1422:10)
    at Module.load (node:internal/modules/cjs/loader:1203:32)
    at Module._load (node:internal/modules/cjs/loader:1019:12)
    at Module.require (node:internal/modules/cjs/loader:1231:19) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/usr/src/forge/app/node_modules/@flowfuse/flowfuse/forge/forge.js',
    '/usr/src/forge/app/node_modules/@flowfuse/flowfuse/forge/app.js'
Node.js v18.20.3
Someone any idea what I'm doing wrong?
Thanks for mentioning this, it looks like a bug in the packaging, we'll get it fixed as soon as possible.
Hi, new containers released that should fix this. If you run
docker compose down
docker compose pull
docker compose up -d -p flowfuse
It should work now
Yes it's working now, thank you!!
