Hello, I have the following problem:
I have two servers connected via WireGuard. Server 1 is running "Node-Red" with the FlowFuse Dashboard, while Server 2 is running an NGINX server.
Here's the NGINX configuration.
location /dashboard {
add_header X-Client-IP $remote_addr;
proxy_pass http://10.0.0.2:1880/dashboard;
proxy_http_version 1.1;
proxy_cache_bypass $http_upgrade;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header Connection "upgrade";
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Port $server_port;
When opening a dashboard page from the internet and checking the UI-control debug...
msg : Object
payload: "connect"
_client: object
socketId: "bN9KYr7qntlYVpl_AAAB"
socketIp: "10.0.0.1"
_msgid: "07e64a4f673bc9d3"
Do you know how I can get the real IP address into the socketIp (or any other method)?
Thank you!
