FlowFuse: run python script with library dependancies that do not exist
Greetings,
I have an instance in FlowFuse where I need to execute some Python scripts that use libraries like pandas, sklearn, and joblib amongst others.
However, I get the error: "ModuleNotFoundError: No module named 'pandas'"
and when I try to pip (or pip3) install pandas, I get a "/bin/bash: line 14 Permission denied" error.
What is the workaround for that?
I appreciate any help you can provide.
Kind Regards
Hi @nsakellion,
It seems like the pandas module is not installed, and when you try to install it, you're getting a "permission denied" error. This usually happens due to a lack of administrative privileges.
Try installing pandas with admin privileges in the terminal first. Once it's installed, you can proceed with other operations from node-red
Also, did you checked this article Calling Python Script from Node-RED, it might provide additional helpful insights.
