Form Cancel button - why no msg?
Hi There!
Why doesn't the cancel button a form trigger a msg just as the submit does? I want to use the form to accept or decline something with both actions should trigger follow-on actions. ATM, I need to use a separate decline button since the cancel button simply clears the form and nothing else. The disadvantage is that this separate button can't access the values in the form (e.g. a reason for declining or accepting something).
Sorry for the repetition because I'm sure this has been asked many times, just I didn't find an answer...
Thank you for any tips!
Can not answer your question as to why.
But, have you tried using the notification ui node. which sends ok, cancel and input.
