Form Node - Time and Date field datatypes
Hi at all,
I'm going crazy trying to figure out what format ui-form sends date and time fields in, specifically when DST exists; can someone explain this to me? Specifically, does it depend on the OS, on the browser? The machine time affects it's resoult?
Alan
It would be helpful if you would tell us
  1. what version of NR and node.js you are using (see startup log)
  2. what version of the dashboard you are using: dashboard 1 or 2?
  3. are you using Docker of Home Assistant?
  4. what device are you running NR on?
Have you added adebug node to the output of the ui-form node to see the results?
If you are using the old original node-red-dashboard then this issue may help to explain the issue. Basically with the old dashboard the situation is not ideal. It is much improved on the newflowfuse dashboard node-red-dashboard (node) - Node-RED.
