Format dashboard text input time seconds
I'm looking for a way to format text input in time mode to display seconds. As I understand for this I would need to add attribute step="1" to input. So the code should look like this:
<input type="time" step="1" ng-change="me.valueChanged(300)" ng-model="timeInput">
is there a way to change default step="any" to step="1"?
Regards
What I had found out is that if I use ui_template node and add attribute step to inputs of type time:
<script>
    $("input[type='time']").attr('step', 1);
</script>
the display is working and showing also seconds, but they are always 00. It looks like code behind is not working correctly.
If you execute $("input[type='time']").attr('step',1) in the browser console manually, does it work?
Was the ui-template set for head mode?
Maybe you need to delay the code (like set timeout or on document ready or angular equivalent)
If I execute the code in the browser manually it also does not work. The seconds stay to 00.
Seconds should in both cases read 20
Adding attribute step does not affect the value or format of an input. It affects what happens when you use the arrows to adjust the time.
TBH, I am not 100% certain what you are trying to do.
Does this help?
Demo flow...
[{"id":"7c5c3d40.626854","type":"ui_template","z":"5f3f2677.c5a0d8","group":"a9584ee2.24eac","name":"","order":1,"width":"8","height":"1","format":"<!-- INSTRUCTIONS...\n* Add as many time inputs as required\n* Set the data-topic attribute unique on each time input\n* When you need to set time from node-red, set the topic to match and the payload to a time string \n* When this node transmits to node-red, the topic will be set to the data-topic you entered\n-->\n\n<div>\n    <label> <span style=\"width: 100px\">Start </span>\n        <input data-topic=\"start\" \n            class=\"my-time\" type=\"time\"  step=\"1\" > \n    </lable>\n    <label> <span style=\"width: 100px\">End </span>  \n        <input data-topic=\"end\" \n            class=\"my-time\" type=\"time\"  step=\"1\" >\n    </lable>\n</div>\n\n<script>\n    (function(scope) {\n        console.log(\"in scope\")\n\n        scope.$watch('msg', function(msg) {\n            if (msg && msg.topic) {\n                var timeInput = $('.my-time[data-topic=\"'+msg.topic+'\"]' );\n                timeInput.text(msg.payload);\n                timeInput.val(msg.payload);\n            }\n        });\n        $('.my-time').change(function(e) {\n            var $this = $(this);\n            var pl = $this.val();\n            var tp = $this.data(\"topic\");\n            scope.send({topic: tp, payload: pl})\n        })\n    })(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":260,"y":540,"wires":[["99a3aef7.c02d9","2db29788.fe97b8"]]},{"id":"ac897c5b.4e01b","type":"inject","z":"5f3f2677.c5a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"start","payload":"09:05:30","payloadType":"str","x":90,"y":520,"wires":[["7c5c3d40.626854"]]},{"id":"99a3aef7.c02d9","type":"debug","z":"5f3f2677.c5a0d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":410,"y":540,"wires":[]},{"id":"d19c063a.ce1d48","type":"inject","z":"5f3f2677.c5a0d8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"end","payload":"09:15:00","payloadType":"str","x":90,"y":560,"wires":[["7c5c3d40.626854"]]},{"id":"50af8142.7d6de","type":"ui_text","z":"5f3f2677.c5a0d8","group":"a9584ee2.24eac","order":3,"width":"8","height":"1","name":"","label":"Start time entered","format":"{{msg.payload}}","layout":"row-spread","x":330,"y":600,"wires":[]},{"id":"2db29788.fe97b8","type":"switch","z":"5f3f2677.c5a0d8","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"start","vt":"str"},{"t":"eq","v":"end","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":150,"y":620,"wires":[["50af8142.7d6de"],["d459f6f5.b02e48"]]},{"id":"d459f6f5.b02e48","type":"ui_text","z":"5f3f2677.c5a0d8","group":"a9584ee2.24eac","order":4,"width":"8","height":"1","name":"","label":"End time entered","format":"{{msg.payload}}","layout":"row-spread","x":330,"y":640,"wires":[]},{"id":"a9584ee2.24eac","type":"ui_group","name":"Rulliere","tab":"a4cbd78a.6d5d68","order":1,"disp":true,"width":"8","collapse":false},{"id":"a4cbd78a.6d5d68","type":"ui_tab","name":"Cantiere","icon":"dashboard","disabled":false,"hidden":false}]
Hey Steve-Mcl,
thank you for that. This almost solves my problem. What I would need to do is that ui_template code would work in the same way that does normal text input set to the mode time. This means that ui_template should expect payload of type number not string, and should also return the number. This number shoould be the miliseconds from midnight. Realy thank you for this advice.
The problem with sending an epoch is there is no date component. But I'm sure you can work around that to suit your needs.
I had managed to come up with this code:
<md-input-container>
    <label>ON time</label>
    <input type="time" ng-model="OnTime" step="1" ng-change="onTimeValueChanged()">
</md-input-container>
<script>
    (function(scope) {
            var d = new Date();
            d.setTime(msg.payload);
            scope.OnTime = d;
        scope.onTimeValueChanged = function onTimeValueChanged() {
            scope.send({payload: scope.OnTime.getTime()});
    })(scope);
</script>
It does exactly what I need to, but the problem is that time is now formatted in my time zone (GMT+1) and not in UTC. This means when I'll input time EPOCH of 0, the time picker will show 1:00:00. Does anyone have a solution for that?
Here is the full flow:
[{"id":"b57c3a4d.b4ba68","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"e5ea476b.7210b8","type":"inject","z":"b57c3a4d.b4ba68","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":260,"y":320,"wires":[["54b3edb0.003c04"]]},{"id":"54b3edb0.003c04","type":"ui_template","z":"b57c3a4d.b4ba68","group":"9e990ee6.a6b1","name":"","order":0,"width":0,"height":0,"format":"<md-input-container>\n    <label>ON time</label>\n    <input type=\"time\" ng-model=\"OnTime\" step=\"1\" ng-change=\"onTimeValueChanged()\">\n</md-input-container>\n\n\n<script>\n    (function(scope) {\n        scope.$watch('msg', function(msg) {\n            var d = new Date();\n            d.setTime(msg.payload);\n            scope.OnTime = d;\n        });\n        scope.onTimeValueChanged = function onTimeValueChanged() {\n            scope.send({payload: scope.OnTime.getTime()});\n        }\n    })(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","x":560,"y":200,"wires":[["88654a1d.971718"]]},{"id":"d2595ac6.2ef818","type":"inject","z":"b57c3a4d.b4ba68","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"120000","payloadType":"num","x":260,"y":200,"wires":[["54b3edb0.003c04"]]},{"id":"88654a1d.971718","type":"debug","z":"b57c3a4d.b4ba68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":800,"y":200,"wires":[]},{"id":"ac683bec.fba3d8","type":"inject","z":"b57c3a4d.b4ba68","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"60000","payloadType":"num","x":250,"y":260,"wires":[["54b3edb0.003c04"]]},{"id":"9e990ee6.a6b1","type":"ui_group","z":"","name":"Osvetlitev HTML","tab":"33440cb5.bb2554","order":2,"disp":true,"width":"6","collapse":false},{"id":"33440cb5.bb2554","type":"ui_tab","z":"","name":"Test","icon":"dashboard","order":1}]
