Hello again.
A Few things...
- read how to share code or flow json
- Put DEBUG nodes after every NODE to see what happens to the
msgas it travels down the wire. - It is impossible to tell as you have only sent a screen shot.
- We cannot see inside a function node from a screen shot
- Have you read the BUILT IN HELP INFO in the sidebar of the MYSQL node? It tells you how to send SQL to the node.
Lastly, I strongly recommend you spend 20 minutes on this page - working with messages - there is INVALUABLE information that will help you help yourself. Especially the bit about "When you hover over any element, a set of buttons appear on the right"
