Format output of array with carriage returns
Hi, I've been banging my head on this without much success.
The output of my payload will be sent to whatsapp. But it lists everything with a comma and I'd like a carriage return.
[{"id":"c2ca69f3dbe80770","type":"api-call-service","z":"5c26fb4772d3c08c","name":"Whatsapp","server":"a0eea9da.0fe1d8","version":3,"debugenabled":false,"service_domain":"notify","service":"whatsapp","entityId":"","data":"{\"message\":\"{{payload.attributes.entities}}\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":740,"y":420,"wires":[[]]},{"id":"1f76c24e88ac0bea","type":"inject","z":"5c26fb4772d3c08c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":290,"y":440,"wires":[["fc6e9e334e49f3d0"]]},{"id":"fc6e9e334e49f3d0","type":"api-current-state","z":"5c26fb4772d3c08c","name":"Unavailablke sensor","server":"a0eea9da.0fe1d8","version":3,"outputs":2,"halt_if":"2","halt_if_type":"str","halt_if_compare":"does_not_include","entity_id":"sensor.unavailable_entities","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":500,"y":440,"wires":[["fc20e36941d596c7","c2ca69f3dbe80770"],[]]},{"id":"fc20e36941d596c7","type":"debug","z":"5c26fb4772d3c08c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":730,"y":480,"wires":[]},{"id":"a0eea9da.0fe1d8","type":"server","name":"GOOD Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
The output in whatsapp is hard to read, because it's seperated by a comma instead of new line
I'm lacking competence in the functions to change this - I tried several things but they don't work...
My debug info
Any suggesiton please?
I think the HA node allows JSONata
so you could try
{"message": $join($$.payload.attributes.entities, "\n")}
or in a change node before
Set msg.payload.attributes.entities
To JSONata expression $join($$.payload.attributes.entities, "\n")
Hi, thanks, just tested.
this first one results in empty topic
the tester in nodered returns
Invalid example JSON message:
SyntaxError: Unexpected token $ in JSON at position 12
But... the second one worked :slight_smile: with a change node.
[{"id":"c2ca69f3dbe80770","type":"api-call-service","z":"5c26fb4772d3c08c","name":"Whatsapp","server":"a0eea9da.0fe1d8","version":3,"debugenabled":false,"service_domain":"notify","service":"whatsapp","entityId":"","data":"{\"message\":\"{{payload.attributes.entities}}\"}","dataType":"json","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":760,"y":380,"wires":[[]]},{"id":"1f76c24e88ac0bea","type":"inject","z":"5c26fb4772d3c08c","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":290,"y":440,"wires":[["fc6e9e334e49f3d0"]]},{"id":"fc6e9e334e49f3d0","type":"api-current-state","z":"5c26fb4772d3c08c","name":"Unavailablke sensor","server":"a0eea9da.0fe1d8","version":3,"outputs":2,"halt_if":"2","halt_if_type":"str","halt_if_compare":"does_not_include","entity_id":"sensor.unavailable_entities","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","x":500,"y":440,"wires":[["80a495f7dd6a26c8"],[]]},{"id":"fc20e36941d596c7","type":"debug","z":"5c26fb4772d3c08c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":750,"y":420,"wires":[]},{"id":"80a495f7dd6a26c8","type":"change","z":"5c26fb4772d3c08c","name":"Clean","rules":[{"t":"set","p":"msg.payload.attributes.entities","pt":"msg","to":"$join($$.payload.attributes.entities, \"          \")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":380,"wires":[["c2ca69f3dbe80770","fc20e36941d596c7"]]},{"id":"a0eea9da.0fe1d8","type":"server","name":"GOOD Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":false,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30"}]
Except... that whatsapp api built for Home Assistant - or whatsapp API itself doesn't allow the special character... Lots of discussions online about it - tried different things
and %0a notably but none worked :frowning:
So I resolved myseld to add 5 spaces in your change node instead of the line break and it's at least much better.
Thanks a lot.
you need to set to JSONata not JSON
not sure what whatsapp uses as i don't use it, but you could try html <br>or markup \
